Author Topic: Fitting Motad exhaust  (Read 9394 times)
« Reply #15 on: November 17, 2014, 02:00:53 PM »
Nice to hear Ian....
Re: Fitting Motad exhaust
« Reply #16 on: November 21, 2014, 05:29:00 PM »
Hi all. Just a quick update. Been talking to Motad via email and they have been brilliant. Unfortunately neither Motad nor myself are 100% sure what the problem is so we are looking for a workaround solution at the moment. So far they have made me a set of bespoke head rings that arrived today (shorter than standard), should be able to fit the pipes tomorrow. I should then be able to accurately measure for a modified silencer bracket. Never had after sales service as good as this from anywhere. Thanks Motad I really appreciate your help. Cheers.
Offline matthewmosse
« Reply #17 on: November 21, 2014, 07:59:18 PM »
Glad to hear this, I also found Motads after sales was great even buying a used system off ebay they were still able and willing to help with a discontinued rebel 125 system. Better than Honda after sales.
« Reply #18 on: November 21, 2014, 08:07:10 PM »
Forgive me if I have this wrong or misunderstanding not followed it closely but back in the 70s I fitted a motard exhaust cos Honda were too expensive frack me nothing like they are today if you can find them.Dont remember a problem at all except a crappy bracket to hold up the main stand.So please whats different? :D :D
Bitsa
« Reply #19 on: November 22, 2014, 01:21:36 PM »
Hi Bitza. I guess the difference is that yours fitted the cylinder head, whereas mine doesn't. That's why they have provided shorter head rings at 23mm rather than the standard 28mm. Still got the bracket that the stand completely misses to sort out, but just going to the garage now to see if the header pipes will fit with the new head rings. Will report back later. Cheers.
« Reply #20 on: November 24, 2014, 03:59:23 PM »
Exhaust is finally correctly fitted. Motad (bless em) made me some new head rings 5mm shorter and now they fit a treat. On standard Honda studs the nuts tighten up with 2 threads showing through. Perfect. Not got a clue what was happening with the standard head rings. The header to silencer fit was due to "out of round" distortion from welding. I turned a mandrel on the lathe and tapped it in to get them round again, they now fit well. The rear silencer bracket was still miles out. I had to re-bend the bottom of it with a 45 degree bend to get it to meet the centre stand. Got it all perfect now. 10 out of 10 to Motad for after sales service. Shame they couldn't get it right first time. OH well!!
« Reply #21 on: November 24, 2014, 08:15:09 PM »
Are you now working for Motad R&D???
« Last Edit: November 24, 2014, 08:19:53 PM by Trigger »
« Reply #22 on: November 24, 2014, 08:24:29 PM »
Royall
The question is what the hell has motad changed since the mid 70s?
Bitsa
Offline Waggles
« Reply #23 on: November 26, 2014, 10:00:34 AM »
Came a bit late to this but I too had a couple of issues when fitting a Motad 4 into 1 to my F1. I did feedback at the time but for completeness!!
Firstly I couldn't make the thing fit at all. Naturally assumed the problem was with the nut trying to fit the system! turned out 1 header pipe was the wrong one! Motad replaced quickly so no complaints there.
I would feedback though that the header rings were extremely difficult to push round the tight final bend on the header tubes and scratch up the finish. I used standard split collars and all was well. Maybe the shorter ones produced for this user would be better as standard?
« Reply #24 on: November 26, 2014, 01:36:16 PM »
http://www.sohc.co.uk/index.php/topic,4058.0.html
That was my motad I know picture is crap and old but fitted no sweat but like I said stand brkt crap
Bitsa
« Last Edit: November 26, 2014, 01:37:49 PM by Bitsa »
« Reply #25 on: November 26, 2014, 01:57:09 PM »
Found another photo off the rear end are they still the same?
Bitsa
Still cant find her damn shame
« Last Edit: November 26, 2014, 01:58:45 PM by Bitsa »
Offline tom400f
« Reply #26 on: November 26, 2014, 02:01:25 PM »
Bitsa
Girl in that other photo doesn't look too keen Bitsa...
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
« Reply #27 on: November 26, 2014, 02:04:51 PM »
Tom
What girl? thats my mate who is now a harley chop nutter and not that I love em but has made a nice job of it.
Bitsa
Offline tom400f
« Reply #28 on: November 26, 2014, 02:49:33 PM »
Whoever is on NKK 38M but anyway, wouldn't be the first time I'd made that mistake  ::)
1978 CB400F2 Yellow
1995 VFR750FS Red
Offline tom400f
« Reply #29 on: November 26, 2014, 02:50:40 PM »
Suppose if the light's bad enough it might not actually matter  :P
1978 CB400F2 Yellow
1995 VFR750FS Red
