Author Topic: CB750 wheel bearing retainer removal  (Read 1923 times)
Offline martin_uk
« on: November 17, 2014, 08:38:34 PM »
Not sure if covered before, but I learnt the hard way that you need to drill out the staked points on retainer.
Just use a 3mm drill to depth of about 4mm.
Otherwise the threads get damaged and retainer difficult to remove.
2014_0507cb750B40023 by nitram2010, on Flickr
2014_0507cb750B40025 by nitram2010, on Flickr
May need to gently warm outer hub with hot are gun so it expands to make easier.
If threads do get damaged use a thread tap with same pitch as a scraper to clean up.
I bought a new genuine retainer and it would not screw in.
After cleaning threads with a tap it went in fine.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline UK Pete
Re: CB750 wheel bearing retainer removal
« Reply #1 on: November 17, 2014, 08:47:04 PM »
Been there done that and learnt from my mistake, its so much easier to do it properly
pete
Offline martin_uk
« Reply #2 on: November 17, 2014, 09:00:20 PM »
pete
I was annoyed with myself as in most other applications you can remove without drilling out :-[
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
« Reply #3 on: November 17, 2014, 09:05:34 PM »
With you all on that one if you have the tool easee pezee
Bitsa
« Reply #4 on: November 17, 2014, 09:22:26 PM »
Bitsa
I have one at the moment that will not move, even with the right tool. Someone has put retainer on the thread >:(
