Author Topic: Small Plate location CB500 Four  (Read 3821 times)
« on: November 18, 2014, 11:57:17 AM »
Anyone have an idea where part number 50400-323-000 goes on a CB500K0. The microfiche shows the part but, not its location.Help
Re: Small Plate location CB500 Four
« Reply #1 on: November 18, 2014, 12:37:13 PM »
According to Google it's an Ignition Coil Cable protector which you probably already know, so I may have been no help to you at all Trigg  :-* :-*
Offline simonster
« Reply #2 on: November 18, 2014, 12:53:13 PM »
The attached should help.
Offline simonster
« Reply #3 on: November 18, 2014, 12:54:16 PM »
And this..
Offline simonster
« Reply #4 on: November 18, 2014, 12:57:26 PM »
Sorry the images aren't too clear, it is part number 19 which is a protective plate for the hytension leads.
« Reply #5 on: November 18, 2014, 01:02:59 PM »
No worries girl. I know what it is but, can't find a place for it :'(
Simon, It has a hole but, the hole is a little too big for the bolt on the coils.
« Reply #6 on: November 18, 2014, 01:13:12 PM »
is it the soft metal clip/strap ,and the hole is the pin the round tank rubbers fit on?
Offline simonster
« Reply #7 on: November 18, 2014, 01:31:31 PM »
I found that mine was missing  and I made a plate from thin ally to fit the 6 mm bolt that threads through the ignition coil bracket. It wasn't essential but keeps the leads from gaping.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #8 on: November 18, 2014, 01:36:45 PM »
Trig... no 500' knowledge, but it is this part - ie to keep #1 & #4 ign leads clear of gubbins abouts the top of the cylinder head?
S
« Last Edit: November 18, 2014, 01:44:46 PM by Lobo »
Offline simonster
« Reply #9 on: November 18, 2014, 01:42:55 PM »
I should also say, I'm still a novice on the renovation of these motors and I could be wrong. That said the piece I made does the job as I suggested.
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« Reply #10 on: November 18, 2014, 02:17:46 PM »
here you go Trig, it protects / guides the blue wire from the coil to the loom. Or at least thats what it does on mine ! ..... while noting that the parts diagram has it the other way round and the other way up
« Last Edit: November 18, 2014, 02:23:16 PM by Ewan 500 K1 »
500K1 basket case for later
Offline Ewan 500 K1
« Reply #11 on: November 18, 2014, 02:18:43 PM »
and another [ Guests cannot view attachments ]
« Reply #12 on: November 18, 2014, 04:44:47 PM »
Cheers Ewan, Bloody strange little part and all for one wire. You also have a bolt missing out your horn mate.
« Reply #13 on: November 18, 2014, 04:49:13 PM »
That's a harness strap/hook that goes on the left side John.
Offline mickwinf
« Reply #14 on: November 18, 2014, 05:55:21 PM »
on mine its like this but don't know if its correct, ewans way looks more logical.
