Author Topic: Turning without a lathe  (Read 1465 times)
Offline martin_uk
« on: November 22, 2014, 01:10:33 PM »
I dont have a lathe and needed to turn down an M6 bolt to replace a broken seat stud.
It is not visible once cover fitted, but I like to play ;D
I am sure many of you will have used a drill mounted in vice with a file to shape, but it works even better if you have a grinding wheel.
Mount the bolt in drill and whilst operating drill and grinding wheel, shape the bolt against the wheel.
This gives a much more even finish.
Drilled out the stud and counter sunk.
2014_1122kparts0052 by nitram2010, on Flickr
2014_1122kparts0054 by nitram2010, on Flickr
I later added a bevel to allow bolt to fit counter sunk.
Will need welding to finish
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
