Author Topic: Sump Mess  (Read 3021 times)
Offline Lynx
  • Repair & Despair Under One Roof
Sump Mess
« on: November 24, 2014, 09:18:08 PM »
I'm still building up my spare engine and just digging out the outer casing for cleaning and spraying. I have two sumps but both have been over tightened and cracked. I know the other one leaks a bit, so I'd prefer to use this one. The question is, would you grind down this bird shit welding or leave it as it is?
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Re: Sump Mess
« Reply #1 on: November 24, 2014, 09:22:21 PM »
If it has been welded form the inside as well, you should be safe to sand the mess down. Just be careful.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Sump Mess
« Reply #2 on: November 25, 2014, 12:11:30 AM »
If no luck sanding the mess away then this guy has a sump in good nick (according to his web page )
http://www.400fourbits.co.uk
Simon
Offline Lynx
Re: Sump Mess
« Reply #3 on: November 25, 2014, 07:07:08 AM »
Thanks guys. I'll take a look at that sump and good point Trigger. It hasn't been welded on the inside. In fact I can see quite a bad crack in there. So best to leave alone I think.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Re: Sump Mess
« Reply #4 on: November 25, 2014, 07:14:01 AM »
Before use i would be tempted to fill it with diesel or parafin and leave it standing to see if any gets through the crack/weld
Offline Lynx
Re: Sump Mess
« Reply #5 on: November 25, 2014, 07:16:51 AM »
Will do.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Clem2112
  • Midlife
Re: Sump Mess
« Reply #6 on: November 25, 2014, 12:23:38 PM »
Memories  :(
- After cracking the sump on mine (I blamed Honda for placing that drain hole in a weak area on the corner and with too few threads !)
I had it welded very neatly at work and a collar welded on to provide some more thread length before re-tapping.
Never broke again but I had learned not to overtighten -got a couple more cracked ones repaired in the same way.
Offline sweetpeauk
Re: Sump Mess
« Reply #7 on: November 25, 2014, 03:59:22 PM »
I think I have a spare that you can have for cost of postage. will have a peep later.
Paul
CB400F
CB400F2
RVF400
XT500D
CB900F2C
GS1000GT
XS1100E
Offline Lynx
Re: Sump Mess
« Reply #8 on: November 25, 2014, 07:05:15 PM »
That would be great Paul thanks.
Steve
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline sweetpeauk
CB400F
CB400F2
RVF400
XT500D
CB900F2C
GS1000GT
XS1100E
Offline Lynx
Re: Sump Mess
« Reply #10 on: December 04, 2014, 09:41:47 AM »
Hi Paul,
Does that slot go right through?
Steve
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline sweetpeauk
Re: Sump Mess
« Reply #11 on: December 04, 2014, 03:07:00 PM »
No, inside in fine. I would still get it filled though just for peace of mind. Will post if off soon.
Paul
CB400F
CB400F2
RVF400
XT500D
CB900F2C
GS1000GT
XS1100E
Offline Binman180
Re: Sump Mess
« Reply #12 on: December 08, 2014, 06:45:33 PM »
That's some lumpy welding!
I think just taking out some of the most proud parts of the weld and dressing the edges/toes to blend it a bit would make it look a lot better if you're careful
