Author Topic: CB750K8 Project  (Read 49234 times)
Offline martin_uk
Re: CB750K8 Project
« Reply #120 on: February 26, 2015, 08:50:45 PM »
Cleaning up engine parts
2015_0225eng0003 by nitram2010, on Flickr
2015_0225eng0001 by nitram2010, on Flickr
Front mudguard is not too pretty, but dont want to pay for repro one at moment
2015_0225eng0007 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #121 on: February 27, 2015, 10:33:48 AM »
Reassembly of crank cases stalled as I found the drive sprocket shaft seal in kit I had did not fit later larger shaft on K8, so had to order one up from DSS.
It may be possible to fit seal after crank cases together but decided to wait
« Last Edit: February 27, 2015, 07:31:46 PM by martin_uk »
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: CB750K8 Project
« Reply #122 on: February 27, 2015, 07:10:33 PM »
Wise man Martin have it all ready mate
Bitsa
Offline martin_uk
Re: CB750K8 Project
« Reply #123 on: February 27, 2015, 07:36:58 PM »
Crank cases now together, just waiting for rebored cylinders.
On my last install, I left fitting of starter motor, oil filter, oil pump, sump, alternator/ rotor and cover, clutch and selector parts until engine in and will probably do same again.
My rationale is it makes engine quite a bit lighter and easier to handle and as I have a bike lift it is not difficult to fit these after.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: CB750K8 Project
« Reply #124 on: February 27, 2015, 08:04:23 PM »
Like your other post well impressed wish you all the best you deserve it for all your efforts brilliant
Bitsa
Offline martin_uk
Re: CB750K8 Project
« Reply #125 on: February 27, 2015, 08:26:54 PM »
Bitsa
Thanks Bitsa, it is nice when you get to reassembly stage
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline UK Pete
Re: CB750K8 Project
« Reply #126 on: February 28, 2015, 08:42:00 AM »
quite agree the less on it the easier it gets, you do some really good work martin and really show us up for being so slow keep it up fella its great to see your progress
pete
pete
Offline martin_uk
Re: CB750K8 Project
« Reply #127 on: February 28, 2015, 12:56:04 PM »
pete
pete
I hope my updates help inspire/motivate others, but it is difficult to keep motivated in the cold weather.
The K8 tank is finished but as it is over 100 miles away I wont be able to collect until week after next :'(
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: CB750K8 Project
« Reply #128 on: February 28, 2015, 07:17:57 PM »
With you there Martin its so cold here and the moment I get an urge I open the garage door and in seconds all and sunder is wet.Shut door and not touch a thing.Does iss me off big time
Bitsa
Offline martin_uk
Re: CB750K8 Project
« Reply #129 on: February 28, 2015, 09:45:39 PM »
Started on the head.
Most of valves semi seized and had to be tapped out of head.
2015_0228eng0018 by nitram2010, on Flickr
2015_0228eng0011 by nitram2010, on Flickr
2015_0228eng0012 by nitram2010, on Flickr
Cleaned up, I use a bench electric wire brush and finish with emery cloth with valve in pillar drill.
2015_0228eng0023 by nitram2010, on Flickr
2015_0228eng0021 by nitram2010, on Flickr
2015_0228eng0027 by nitram2010, on Flickr
I will see if valves lap in OK
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #130 on: March 01, 2015, 02:30:23 PM »
A couple of the exhaust seats will need recutting.
2015_0301eng0003 by nitram2010, on Flickr
Others OK
4 of valves have worn or pittedstem tops.
2015_0301eng0009 by nitram2010, on Flickr
Hopefully can find some used spare ones in my stash in shed ;)
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #131 on: March 01, 2015, 07:34:50 PM »
Found some spare valves but all the earlier type with wide collet groove :(
Dont realy want to mix different collets
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #132 on: March 03, 2015, 06:11:15 PM »
DSS is £35 for exhaust valve and £27.20 for inlet, CSMNL is E54 and E49 !
 Found 1 exhaust on Ebay UK for £15 inc and 1 exhaust and 2 inlet from Ebay France for £45.
Current spend including purchase is £3500 and still need to sort seat and 1 exhaust!!
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #133 on: March 03, 2015, 06:20:18 PM »
Stripped carbs yesterday and on reassembly found one of the float bowl screw thread in body was stripped  ::)
I have helicoils for M5 and M6, but not M4 :'(
For some reason the M4 kit is 3x the cost of M5 one  ???
Does anyone know what size tap is used for M4 helicoil or is it a special size/pitch?
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline ka-ja
  • ken
  • yoshi 460
Re: CB750K8 Project
« Reply #134 on: March 03, 2015, 07:10:06 PM »
Hi,
    Helicoil taps are a specific size to suit the helicoil, and most helicoil sets include the appropriate tap and fitting tool for each size of coils in the set!---ken
nice bike,nothing in the bank
