Author Topic: CB750K8 Project  (Read 48987 times)
Re: CB750K8 Project
« Reply #15 on: December 06, 2014, 08:18:52 PM »
Have to say the plastic wire blocks are the worst I have seen Is it because acid have got to them? but I do have the fork bottoms
Bitsa
Offline martin_uk
Re: CB750K8 Project
« Reply #16 on: December 06, 2014, 11:23:48 PM »
392 domed piston
2014_1206Kparts30001 by nitram2010, on Flickr
2014_1206Kparts30003 by nitram2010, on Flickr
2014_1206Kparts30002 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: CB750K8 Project
« Reply #17 on: December 07, 2014, 09:17:32 AM »
Thanks for that Martin. Those 392 piston's are a little difficult when it comes to finding ring's. If you have any idea who is doing rings for those i would be interested. Cheers
Offline UK Pete
Re: CB750K8 Project
« Reply #18 on: December 07, 2014, 09:30:11 AM »
I thought they took the same rings as the f2
Pete
Re: CB750K8 Project
« Reply #19 on: December 07, 2014, 09:37:14 AM »
Pete
Same rings as the F2 pete but, hard to find at the right price.
Offline martin_uk
Re: CB750K8 Project
« Reply #20 on: December 07, 2014, 11:01:18 AM »
I got some standard size ones from Davis Silver for my F1 that had same pistons. They were £76 plus vat and P&P for full set, though :'(
Made by NPR and listed as OEM  13011392004P
« Last Edit: December 07, 2014, 11:08:34 AM by martin_uk »
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline UK Pete
Re: CB750K8 Project
« Reply #21 on: December 07, 2014, 12:37:16 PM »
Thats the ones they fit k7 and f2, the k8 is virtually the same as k7 so makes it easier when searching for parts
only problem with the rings is they only seem top do standard size
pete
Re: CB750K8 Project
« Reply #22 on: December 07, 2014, 02:27:02 PM »
Too rich for me. DSS is well over priced these days. Just did a price check on 10 items from DSS and compared the same items with a German dealer that i use. The result was DSS was £83 more expensive.
Re: CB750K8 Project
« Reply #23 on: December 07, 2014, 04:40:28 PM »
DSS has all ways been more than most got to pay for the USA warehouse
Bitsa
Offline martin_uk
Re: CB750K8 Project
« Reply #24 on: December 07, 2014, 05:28:56 PM »
Hi Trigger,Could you advise German dealer details and I will check them out.
Put a list of some of parts on DSS basket and came to £280  :'(
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: CB750K8 Project
« Reply #25 on: December 07, 2014, 06:07:01 PM »
Sent you a list PM.
Offline UK Pete
Re: CB750K8 Project
« Reply #26 on: December 07, 2014, 06:25:53 PM »
Hi trigg pm me the german contact please
pete
Offline martin_uk
Re: CB750K8 Project
« Reply #27 on: December 07, 2014, 08:29:56 PM »
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #28 on: December 08, 2014, 05:39:24 PM »
Stripped frame and parts dropped at powder coaters.
2014_1208Kparts50049 by nitram2010, on Flickr
2014_1208Kparts50046 by nitram2010, on Flickr
Just realised I forgot to drop off the handle bar clamps  :'(
The seat pan needs alot of work as cracked and rusted through :'(
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #29 on: December 08, 2014, 05:52:48 PM »
Front brake caliper was the usual pain ::)
First the bleed nipple was seized, took lots of heating and soaking over 2 days, find a deep 8mm socket is good used with 1/4 drive ratchet to get a better feel and hopefully not snap nipple.
Feels a bit like playing Russian roulette getting these out :P
Once that was out, had to refit to try air pressure to push out piston.
Would not move, but managed to push piston in a bit but would not come out with air pressure, soaked with WD40 for a couple of days.
Eventually used the grease gun method, using an adaptor with grease nipple and pumped in grease.
Came out fine.
2014_1208Kparts50043 by nitram2010, on Flickr
2014_1208Kparts50045 by nitram2010, on Flickr
2014_1208Kparts50044 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
