Author Topic: CB750K8 Project  (Read 48996 times)
Offline martin_uk
Re: CB750K8 Project
« Reply #90 on: January 27, 2015, 04:36:57 PM »
Martin, did you receive the fork cap mate ?
Thanks Trigger, Yes looks good, hopefully soon to fit wheel.  :)
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #91 on: January 28, 2015, 06:29:32 PM »
Fitted tyre, always feels as if you are making some progress when tyres go on  :)
2015_0128frame0003 by nitram2010, on Flickr
Had to deflate tyre and reinflate at higher pressure to get seated correctly, with guide marks even.
2015_0128frame0006 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #92 on: January 28, 2015, 06:35:53 PM »
Rear tyre fitted
2015_0128frame0013 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #93 on: February 07, 2015, 04:28:34 PM »
Dont you just hate it when you spend ages on a part to then find its the wrong one  :-[
The rear mudguard looked to be in reasonable condition, with some rust on inside.
Spent ages cleaning this off with wire brushes, emery and scouring pads, then painting inside, to find the rear mounts dont line up  :'(
2015_0207frame0018 by nitram2010, on Flickr
2015_0207frame0012 by nitram2010, on Flickr
Having looked at parts diagram, seems correct one has a sort of extension piece at front mount.
Not sure what the one I have is for?
2015_0207frame0020 by nitram2010, on Flickr
Its a US import, does anyone know what this bracket/holder is for?
2015_0207frame0021 by nitram2010, on Flickr
Does this mean the tail light bracket is wrong too?
2015_0207frame0025 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #94 on: February 07, 2015, 04:33:15 PM »
Made a bit more progress.
2015_0207frame0037 by nitram2010, on Flickr
2015_0207frame0040 by nitram2010, on Flickr
2015_0207frame0041 by nitram2010, on Flickr
2015_0207frame0036 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline UK Pete
Re: CB750K8 Project
« Reply #95 on: February 07, 2015, 04:38:24 PM »
Good work martin, i just cant get any motivation lately to do anything
pete
Offline martin_uk
Re: CB750K8 Project
« Reply #96 on: February 07, 2015, 04:41:47 PM »
Wheels balanced
2015_0207frame0031 by nitram2010, on Flickr
Tape is just to give self adhesive weights a bit of support until bonded.
Considered going for 530 conversion but as bought fairly cheap NOS 630 sprocket decided to keep original
2015_0207frame0033 by nitram2010, on Flickr
Light polish on brake plate
2015_0207frame0034 by nitram2010, on Flickr
« Last Edit: February 07, 2015, 05:13:35 PM by martin_uk »
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #97 on: February 07, 2015, 04:50:22 PM »
pete
I know what you mean Pete, as it can be a struggle sometimes :(
I sometimes just do a few small jobs, on the basis that its one more less job to do.  :)
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline mickwinf
Re: CB750K8 Project
« Reply #98 on: February 07, 2015, 05:11:06 PM »
I had a mudguard like that with the metal box, turned out to be a cb650 US import.
Re: CB750K8 Project
« Reply #99 on: February 07, 2015, 05:26:28 PM »
Martin. Who does your plating, looks like a top job. What sort of prices do they charge. Bikes coming on a treat, been interesting to follow with all the photos. Thanks.
Offline martin_uk
Re: CB750K8 Project
« Reply #100 on: February 07, 2015, 05:44:55 PM »
Thanks, I  use http://mercuryelectroplating.com/ have to electric wire brush first, usually around £30 plus vat  for shoe box size batch, can do clear (silver) colour (yellow) and black
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #101 on: February 09, 2015, 06:05:56 PM »
One job I dislike is cleaning out petrol tanks :'(
On the K8 the inside was gummed up and looked like molasses!
Tried adding fresh fuel and soaking for a few weeks but no luck.
In meantime I had tank blasted and etch primed as this saves lots of time rubbing down rusty areas and co I use moans about it and I hope reduces their/my costs.
You do not want to be cleaning inside once painted as very easy to damage with spillage.
2015_0209frame0001 by nitram2010, on Flickr
As petrol didnt work I used cellulose paint thinners, with some nuts to shake about.
2015_0209frame0002 by nitram2010, on Flickr
That worked quite well but you need to do in well ventilated area (outside) and wear protective gloves etc.
The first drain out was really dark and I probably drained and refilled (approx 2-3 litres) about 10 times, in the freezing cold  :o
I used a stainless funnel and kitchen towel as filter paper to make sure I wasnt putting grit back in and also allows you to see how much is coming out. Also best to leave sediment in the bottom of container when reusing.
2015_0209frame0004 by nitram2010, on Flickr
2015_0209frame0008 by nitram2010, on Flickr
The problem is knowing when to stop.
Dropping tank, filler cover and new replica side panels off for painting tommorrow.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project mudguard
« Reply #102 on: February 14, 2015, 05:46:35 PM »
After the annoyance of finding the wrong rear mudguard came with bike, looked at ones available.
A fairly rough one was £70, so thought about options.
The correct part looks like it is modified with a short extension piece.
It got me thinking, maybe I could make an adaptor 8)
Started with a cardboard template and an offcut of ally sheet.
Bent in vice with guide piece and rubber mallet.
2015_0214frame0007 by nitram2010, on Flickr
2015_0214frame0009 by nitram2010, on Flickr
2015_0214frame0012 by nitram2010, on Flickr
Check fit, sides are different shapes.
An old stanchion came in handy
2015_0214frame0017 by nitram2010, on Flickr
Sprayed satin black
2015_0214frame0026 by nitram2010, on Flickr
2015_0214frame0029 by nitram2010, on Flickr
2015_0214frame0036 by nitram2010, on Flickr
Quite pleased with the result  :D
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project indicators
« Reply #103 on: February 14, 2015, 05:56:36 PM »
Bike did not have any indicators when I bought.
Ebay purchases were not too bad , but needed a new lamp holder as rusted up.
Decided to try DSS replica ones for front.
Seem quite good for price at £7.95 plus vat and del.
2015_0214frame0002 by nitram2010, on Flickr
2015_0214frame0003 by nitram2010, on Flickr
Wondered if originals lens would fit.
Original on left, note longer original screws.
2015_0214frame0005 by nitram2010, on Flickr
They do fit but need care to avoid cracking and you need to use original screws.
My tip for fitting light cover screws without breaking, is just use fingers on screwdriver and no wrist action  :P
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750K8 Project
« Reply #104 on: February 14, 2015, 06:04:33 PM »
A bit more progress
Front wheel and caliper fitted.
2015_0214frame0042 by nitram2010, on Flickr
Rear wheel, mudguard, indicators and grab rail
2015_0214frame0041 by nitram2010, on Flickr
2015_0214frame0040 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
