Author Topic: Xr75  (Read 2454 times)
Offline Woodside
Xr75
« on: December 14, 2014, 07:39:51 PM »
Hi just a stab in the dark
I picked up this little 1975 xr75....
I think ineed a new fuel tap  ...as the one on it keeps letting by no matter where the lever is ...I have put a new rubber in its still the same there must be something else letting by possibly in the body....it has stood for some time
Any thoughts or does anyone know where I can source one ds and cmsl can only help with spares...but I've done that?
Cheers in advance
Re: Xr75
« Reply #1 on: December 14, 2014, 07:41:38 PM »
Christ forgot about those remember the 125 well best of luck
Bitsa
Re: Xr75
« Reply #2 on: December 14, 2014, 07:47:36 PM »
Look up a universal tap for that. They were only available in the USA so it will be hard to find a tap.
« Last Edit: December 14, 2014, 07:52:29 PM by Trigger »
Offline Woodside
Re: Xr75
« Reply #3 on: December 14, 2014, 07:49:18 PM »
Yeah it's a survivor ...and it has a v5 ......just passed the mot too?
I forgot to say its the fuel tap with one 6mm fixing through the middle not the later bzp (I think that's right) fitting
I think some other small honda taps are similar so maybe someone can tell me if another is compatible
« Last Edit: December 14, 2014, 07:51:52 PM by Woodside »
Re: Xr75
« Reply #4 on: December 14, 2014, 07:52:30 PM »
Still Nice lucky you
Bitsa
Re: Xr75
« Reply #5 on: December 14, 2014, 07:54:25 PM »
Should have this type >>>  http://www.cmsnl.com/honda-xr75-1976-usa_model853/partslist/F++07.html#results
If this is the right one. One new one available in the states £18.64 all in.
« Last Edit: December 14, 2014, 08:01:33 PM by Trigger »
Offline Woodside
Re: Xr75
« Reply #6 on: December 14, 2014, 08:02:30 PM »
Yep that's the one
I puts new rubber (no6)
Thought that would  sort it?
Re: Xr75
« Reply #7 on: December 14, 2014, 08:09:59 PM »
Offline Woodside
Re: Xr75
« Reply #8 on: December 14, 2014, 08:26:47 PM »
Cheers trigg
I did see the USA ones I did figure that was the route I was going to have to go......I was kinda hoping to find a uk supplier....still there cheap enough not to have my pants pulled down on import taxes...
Re: Xr75
« Reply #9 on: December 14, 2014, 08:29:04 PM »
Did a UK search but, nothing with that part number. USA bike.
Re: Xr75
« Reply #10 on: December 14, 2014, 08:30:33 PM »
As Usual gits get all the good stuff
Bitsa
Offline Woodside
Re: Xr75
« Reply #11 on: December 14, 2014, 08:36:37 PM »
Just placed an order so all I need to do is sit back and forget about it....
Was just under £20 delivered
I'm ok with that
Thanks again
Re: Xr75
« Reply #12 on: December 14, 2014, 08:37:54 PM »
I'm ok with that
Thanks again
Knowing you, you did not pay a lot for the bike.
Offline Woodside
Re: Xr75
« Reply #13 on: December 14, 2014, 08:42:49 PM »
Yeah I couldn't turn it down. ....it's a nice little thing and a proper bike to boot not the usual mini bike stuff you see banded about
