Author Topic: f2cafe racer  (Read 69603 times)
Offline yozzer74
Re: f2cafe racer
« Reply #195 on: December 20, 2015, 10:29:03 AM »
I got them off trigger on here give him a pm .
Re: f2cafe racer
« Reply #196 on: December 20, 2015, 11:14:46 AM »
Cheers Yozzer will send him a PM. May wait a week or so as they don't have internet at the moment.
Offline MCTID
Re: f2cafe racer
« Reply #197 on: December 20, 2015, 03:18:53 PM »
Hi Roy........if you can, please get one for the CB750 motor as well........
Re: f2cafe racer
« Reply #198 on: December 20, 2015, 04:55:14 PM »
That's the one I'm really after Alan. Gave up on doing mine as I couldn't find the parts and its not really bad enough to be worth doing now.
Will do yours whilst the engine is apart if Trigger can come through. Cheers Roy.
Offline yozzer74
Re: f2cafe racer
« Reply #199 on: December 20, 2015, 06:56:11 PM »
I've got a couple of questions about the engine .the studs in the head are in tight do I need to get them out and put thread  sealant on them .next does anyone no what goes in these holes if it's a notch pin do I need them because they weren't there when I stripped engine thanks [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Offline UK Pete
Re: f2cafe racer
« Reply #200 on: December 20, 2015, 10:01:31 PM »
Those studs should already been sealed but are prone to leaking  if some one has removed them in the past so probably worth sealing if they come undone ok
The knock pins and rubbers on the f2 head are reduced to 4  on the outer studs but on the k models there are 8 the oil drains down the inner ones on the k model, you would be wise to study the parts you need for the f2 as they are different from the k, you have to have dome nuts and copper washers on the 4 studs that dont have the knock pins, and little rubber o rings at the base of the barrels on two of the studs  these never come in gasket sets
pete
Offline yozzer74
Re: f2cafe racer
« Reply #201 on: December 20, 2015, 10:07:58 PM »
So I will need to get the notch pins then + I need to get some o rings then
Offline UK Pete
Re: f2cafe racer
« Reply #202 on: December 21, 2015, 08:36:59 AM »
F2
F1 and some K models
Definitely get a parts manual and check out f2 engine build threads on here and us site
Offline yozzer74
Re: f2cafe racer
« Reply #203 on: December 21, 2015, 01:53:51 PM »
Cheers Pete can't say I'm looking forward to building this back up
Offline yozzer74
Re: f2cafe racer
« Reply #204 on: December 21, 2015, 03:25:20 PM »
Offline yozzer74
Re: f2cafe racer
« Reply #205 on: December 21, 2015, 03:27:15 PM »
Found this it mentions that he didn't use the notch pins in it  .
Offline yozzer74
Re: f2cafe racer
« Reply #206 on: December 29, 2015, 06:34:26 PM »
Ordered missing parts I need & o rings .been cleaning gasket surfaces up and noticed one of the cylinder sleeves as a slight bit of damage on it .making it sit higher than the sealing surface .do I need to get it skimmed or would I be ok trying to sand it down ?? [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Re: f2cafe racer
« Reply #207 on: December 30, 2015, 10:31:45 AM »
Just carefully drawfile and wet n dry
Offline yozzer74
Re: f2cafe racer
« Reply #208 on: December 30, 2015, 10:44:18 AM »
Just taken it back to machine shop .he's going to check with gauge if rest of its ok he say he will just file it up .
Offline Coppertop1234
Re: f2cafe racer
« Reply #209 on: January 03, 2016, 04:44:12 PM »
Just been and seen Yozzers project in the flesh - its looking excellent!! and is a credit to your the detailing you have in your design
Keep up with the postings Yozzer - Spring will soon be here.
If you need a carb sync (if you don't have one) when your ready give me a mail and I pop it up
I Love Tinkering with Old Classics
