Author Topic: New Member + photos  (Read 5695 times)
Offline Liam
Re: New Member + photos
« Reply #15 on: May 18, 2015, 09:57:35 PM »
Looks fantastic!!
Offline tom400f
« Reply #16 on: May 19, 2015, 01:47:58 PM »
Number plates: saw a Triumph Thruxton (red with the white stripe down the middle) with a black 09 plate. This is Canary Wharf car park and in London they seem to cr@p on you for revenue when you think about rolling a wheel out of place. Wretched CSO Home Guard types.
Oddjob: in my book that is a fight case. Sounds like vigilanti-ism as well  >:(  what's wrong with people??
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Greebo
« Reply #17 on: June 18, 2015, 11:31:57 AM »
Superb build that Greebo, well done. Does it run and tick over okay with the F2 carbs on it?
Hi Roy,
Sorry for the late reply, but I had not got the bike on the road at that point, now I have, & No it did not run properly, it did tick lover OK, but it was lacking fuel, so re-jetted it with 135mains & lifted the needles 2 notches, but it was still missing especially on the 3rd cylinder....back to the workshop, stripped the carbs again & fitted new bowl kit to all 4 carbs , it is now runs spot on...
Question
The only other issue I have is with the clutch, it is a new clutch, but it only pulls away when the leaver is right at the end [as though its ready for a new clutch]  we have tried adjusting on the cable & with the plate off on the internal adjuster. have you or Anyone alse got any ideas ?
« Reply #18 on: June 19, 2015, 03:09:24 PM »
Sounds a bit like the lifter mechanism isn't lifting fully. Its a system where ball bearings run up a ramp as the cable turns the lifter. I would check that as a start point.
Greebo
« Reply #19 on: June 27, 2015, 05:31:24 PM »
Update
After a few teething problems [which are to be expected] the bike is now fully sorted & running like a dream,the performance is much more than I expected...... ;D.. 8)
« Last Edit: June 27, 2015, 05:34:04 PM by Greebo »
« Reply #20 on: June 27, 2015, 05:59:24 PM »
I like that, good job.
« Reply #21 on: June 27, 2015, 07:48:37 PM »
Tell us what cured your clutch, others might have the same problem
Greebo
« Reply #22 on: June 28, 2015, 09:43:15 PM »
With the clutch we simply tried different adjustments until we sorted it, a combination of internal & external tinkering.
With the carb setting issues we first had, we fitted 135 jets & lifted the needles 2 notches from the stock setting, but it was still lacking fuel, so we tried one more notch on the needles & Bingo,it now goes pulls like a train.. 8) could not be happier, but it has took sometime to get here, we started this project last year... :o
