Author Topic: Front Fork spring position  (Read 1879 times)
Offline Piki
« on: March 31, 2015, 10:36:34 AM »
Hello, what position is the correct for the front fork spring of my 550 K3? Tight coils up or down?
Thank you in advance.
Offline ka-ja
  • ken
  • yoshi 460
Re: Front Fork spring position
« Reply #1 on: March 31, 2015, 07:19:33 PM »
Hi,
     Do not know about your machine, but my 400/4 Hagon progressive springs are closer coils down.-Ken
nice bike,nothing in the bank
« Reply #2 on: March 31, 2015, 07:23:06 PM »
That makes sense Ken.
Tighter coils = stiffer spring, so you'd want the ratio to tighten up as you compress the forks (eg under heavy braking) whilst being softer for normal use.
S
2022 Tiger Sport 660
Offline Piki
« Reply #3 on: March 31, 2015, 07:45:58 PM »
Thank you mates,the tight spring coils was on the Top.... I have put it on the bottom now.
Best Regards.
Offline Piki
« Reply #4 on: March 31, 2015, 09:23:29 PM »
Ohh shit! I  notice that I forget put the O'rings on the Forks Bolts!!! Any problem with this??
Offline ka-ja
  • ken
  • yoshi 460
« Reply #5 on: April 01, 2015, 09:10:23 AM »
Hi,
    Apart from oil mist/leakage, you will loose "static" air pressure inside the fork legs which affects damping and rebound,( some bikes have adjustable air pressure settings), put them on one at a time!-Ken
Offline Piki
« Reply #6 on: April 01, 2015, 11:28:47 AM »
Thank you Ka-ja, you are right! The next I will take it appart, is a horror take off the bilts with the bars on the bike...
Offline D C 500
« Reply #7 on: April 10, 2015, 03:01:16 PM »
Tight coils to  the top for hagon springs, I have just fitted these myself to my 500K1. here is a link to hagon-shocks fitting instruction http://www.hagon-shocks.co.uk/common/pagedetail.aspx?PageCode=setup
« Reply #8 on: April 11, 2015, 09:20:23 AM »
Makes sense. Less unsprung weight.
