Author Topic: CB650 comstar interchangeability  (Read 8012 times)
Offline Maxcaddy (Nighthawk)
Re: CB650 comstar interchangeability
« Reply #15 on: November 05, 2018, 03:48:12 PM »
Amazingly enough, ones just popped up on eBay that looked and sounded the part, so I've had a punt.
If it ever gets as far as being stripped, sent to CRK and converted into a spoked one, I'll post some piccy's
« Reply #16 on: February 07, 2019, 12:14:04 PM »
You can also look on wemoto - they have all the bearing dimensions shown, so they're a great source of info if you are mixing and matching between wheels / axles and also fif you are or mixing differnt stems/ yokes into frames.   Once you've worked out what sizes you need you can then go to all bearings (or similar) websites and see if there is an off-the-shelf bearing to fit.
