Author Topic: Brake pads don't fit  (Read 2880 times)
Offline Stuartbellwood
« on: April 11, 2015, 09:30:36 AM »
Hi all
I am in the process of rebuilding the front braking system on a 550f
I have purchased everything new from David silvers but for some reason the pads appear to thick
I.e when I tighten up the two large calliper bolts then the pads lock tight on the disc so it won't turn
Anyone got any ideas of what I'm doing wrong.
Cheers stuart
Offline JustcallmeMrT
Re: Brake pads don't fit
« Reply #1 on: April 11, 2015, 09:34:26 AM »
Hi Stuart, I can't comment myself, but I've seen a few threads in the past that discussed fitment issues with the DSS pads - might be worth a search.  If nothing comes up, I'm sure the experts will chime in shortly.  Good luck!
« Reply #2 on: April 11, 2015, 09:38:29 AM »
Hi all
Cheers stuart
Is the piston back all the way ?
Need more information on what has been replaced. The pivot arm has to be inline with the disc before you try to mount the caliper.
« Last Edit: April 11, 2015, 09:51:11 AM by Trigger »
« Reply #3 on: April 11, 2015, 09:55:52 AM »
Sounds to me like the piston isn't all the way in and/or the pivot siezed
« Reply #4 on: April 11, 2015, 10:26:34 AM »
I've fitted a new calliper, new piston, new seal and new shoes so I know the piston is all the way back
I've also fitted it without the spring loaded adjuster bolt to ensure it isn't that. It really does appear that the pads are just to thick?
Offline Norniron
« Reply #5 on: April 11, 2015, 12:53:32 PM »
Can u post some pics stuart.
Trigger mentioned the pivot arm,is it inline with the disc before fitting the pads?
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #6 on: April 11, 2015, 01:21:43 PM »
Stuart,
             I had exactly the same issues with the pads from DSS.
I ended up getting some 400 grit wet and dry placing it on a flat surface and keeping the pad square rubbing it up and down to take some of the material off the moving pad  :(
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #7 on: April 11, 2015, 01:27:00 PM »
I think he means 'too thick'    Sorry,  just a pet hate of mine
« Reply #8 on: April 11, 2015, 05:46:57 PM »
fair do's to DSS,
  I fitted a couple of sets of his disc pads,and no probs,they fitted in the calipers perfectly,
 other I have used before required the paint to be filed off before they would fit,
« Reply #9 on: April 12, 2015, 08:52:03 AM »
I take it that it is a repro caliper.  As Paul said, he had trouble with the ones he bought from DSS so i would go that way. Never bought bake pads from DSS so, can't comment.
Offline peterengland
« Reply #10 on: April 12, 2015, 04:19:34 PM »
I got some rear shoes from DSS and they wouldn't fit in the drum so I had to rub some material away before they fitted properly so maybe the same problem here?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #11 on: April 13, 2015, 10:27:04 AM »
All the pads from dear spares I have bought never fit without doing something sorry
Bitsa
