Author Topic: 1973 k2 Honda 500 carb problems (Sorted now, was coil wiring issue, not carbs)  (Read 10374 times)
Re: 1973 k2 Honda 500 carb problems
« Reply #45 on: July 09, 2017, 08:36:07 PM »
Nice one, well done Jon.
« Reply #46 on: July 10, 2017, 07:24:27 AM »
One of the boyer ignitions uses standard coils the other uses 6 volt coils in series(or 3 x 4 volt if its a triumph trident)giving extra wasted sparks. Its over 35 years since i fitted one so cant remember which is which
Offline jon stead
This Boyer system uses two, 12volt, coils in series. The difference was unbelievable once I'd rewired them from parallel to series.
This morning, I put the "old", albeit overhauled carbs back on, and it fired up and sat happily idling on the first touch of the starter.
Edit:
Just rereading above, I guess two 6volt coils in series would give 12volt total?
« Last Edit: July 16, 2017, 06:31:28 AM by jon stead »
