Author Topic: Fuel tap replacement k2  (Read 2635 times)
Offline El__burro
« on: April 27, 2015, 11:55:07 PM »
Hello, having to replace the fuel tap (due to a mission spout) I am looking for a replacement part.
Does any other model fit k2 version?
Regards
El__Burro
Re: Fuel tap replacement k2
« Reply #1 on: April 28, 2015, 07:31:09 AM »
Regards
El__Burro
The fuel tap is the same as the 500, early USA 550 and the 750. I have some old taps that have tubes if you require one. MP me your name and address and i will pop one in the post to you  ;)
Honda part number 16950-300-020
Notes   Year   Make   Model   Submodel
    1974   Honda   CB500   --
    1973   Honda   CB500   --
    1973   Honda   CB500   Four
    1972   Honda   CB500   --
    1972   Honda   CB500   Four
    1971   Honda   CB500   --
    1971   Honda   CB500   Four
    1974   Honda   CB550   Four
    1973   Honda   CB550   Four
    1974   Honda   CB750   Four
    1973   Honda   CB750   Four
    1972   Honda   CB750   Four
    1971   Honda   CB750   Four
    1970   Honda   CB750   Four
    1969   Honda   CB750   Diecast Engine
    1969   Honda   CB750   Sandcast Engine
« Last Edit: April 28, 2015, 07:53:17 AM by Trigger »
« Reply #2 on: April 28, 2015, 02:26:35 PM »
Many suppliers of complete taps on ebay, plus Dave Silver of course. Don't forget you need the fibre washers under the heads of retaining screws or fuel will always leak past to the carbs----generic ones don't do the job as they are too thin and split, Honda ones are damned expensive I have used 6mm Dowty washers with success in the past but they aint cheap either
Offline El__burro
« Reply #3 on: June 16, 2015, 07:16:21 PM »
What size fuel pipe i need for a  cb750 K2?
El__burro
« Reply #4 on: June 16, 2015, 07:27:11 PM »
El__burro
The Honda size was 5.5mm ID but, it is no longer available. 5mm ish ID will do the job, Link >>>  http://www.ebay.co.uk/itm/Nitrile-Rubber-Smooth-Fuel-Tube-Petrol-Diesel-Oil-Line-Hose-Pipe-Tubing-Breather-/130740225601?pt=LH_DefaultDomain_3&var=&hash=item1e70b98641
« Last Edit: June 16, 2015, 07:29:25 PM by Trigger »
Offline mickwinf
« Reply #5 on: June 17, 2015, 12:22:57 AM »
5.5mm still available from David Silver
« Reply #6 on: June 17, 2015, 07:24:12 AM »
You will find it is 5.4mm, the same as in the link to Advanced fuel solutions ;)
Offline El__burro
« Reply #7 on: June 17, 2015, 09:43:27 AM »
Bought a 5.5 line.
1 meter should be enough I guess.
El__burro
