Author Topic: What Oil?  (Read 1493 times)
Offline sprinta
What Oil?
« on: May 01, 2015, 09:53:24 AM »
What is the best oil to use with the engines as they have an integral gearbox and clutch?
Is it safe/good to use semi synthetic 10/40W oils that are specifically designed for car engines or do you really need to use 'motorcycle' specific oils or stick with a good old 20/50W?
Not looking for expensive/exotic oils just a good one for general use but there seems to many arguments about not using 'car' engine specific oils as the gearbox 'tears' it apart and possibly causing clutch slip, or is all this just marketing hype to get us to pay more for the same oil?
Online JamesH
Re: What Oil?
« Reply #1 on: May 01, 2015, 10:19:45 AM »
Loads of threads on this already Sprinta - have a good search through the forum.
You'll need a Motorcycle specific oil to avoid clutch slip/contamination....
Re: What Oil?
« Reply #2 on: May 01, 2015, 07:35:24 PM »
in the last set of questions,
 this item came out as the one.
http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/engineoils/10w40-engine-oil/?521776151&0&cc5_245
 the diesel version has a high pressure shear additive ,( I think)
 and pretty good for £17 for 5 ltrs
Offline sprinta
Re: What Oil?
« Reply #3 on: May 03, 2015, 02:05:36 PM »
Thanks for the reply.
Do you have a link to the post in which it was discussed?
Was it considered to be OK with the integral clutch?
Re: What Oil?
« Reply #4 on: May 03, 2015, 07:05:10 PM »
Everything you need is here Sprinta
Regards
Julie
http://www.sohc.co.uk/index.php/topic,7886.0.html
Offline sprinta
Re: What Oil?
« Reply #5 on: May 04, 2015, 01:49:26 PM »
