Author Topic: CB750 F1 Project May 15  (Read 24587 times)
Offline Tiny Tim
Re: CB750 F1 Project May 15
« Reply #30 on: July 05, 2015, 08:56:01 PM »
Great job on the tanks, how long did it take you to achieve such a high standard.
Tim
Offline Coppertop1234
« Reply #31 on: July 05, 2015, 10:08:47 PM »
Hi Tim
We have always been restoring Bikes and Cars using both rattle cans and Air fed systems
We are not professionals, we just both love to keep going till we get it right.
Not always the case with paint, but we have found if your prep work is good the top coats are easy.
Its also the quality of the rattle cans, we always use a proper paint supplier as we have found the pressure and cast of the spray to be a lot better.
Hi Roy
As we say not professionals, but if your stuck when we have finished these I am sure Keith Jnr would consider helping out.The paint costs for our was around £75.00 per tank
Keith Snr
« Last Edit: July 05, 2015, 10:27:19 PM by Coppertop1234 »
I Love Tinkering with Old Classics
« Reply #32 on: July 07, 2015, 02:12:48 PM »
Project 1 nearing completion getting ready for final checks/cleans and MOT - every thing seems ok apart from I have had to remove top front braided hose it was too short and binding on left turn
Heres where she was In May 15 not run since 1990's  and forgot about
Heres a pic of how she stands today
You wouldn't think it took me 3 months to wash it and put mudguard on would you
More pics on Photobucket links:
http://s252.photobucket.com/user/keithjones1400/Honda/story
« Last Edit: July 08, 2015, 08:55:06 PM by Coppertop1234 »
Online AshimotoK0
« Reply #33 on: July 07, 2015, 03:06:50 PM »
What finish do you have on final prep Keith? I have two CB250 tanks that I need to have painted.I have removed most of the paint with (proper) paint stripper but I was considering dry bead blasting them as final prep with 50/100 Vixosheen glass beads. Will this finish be fine enough for candy (or metallic) paint?
http://www.vaporblastingequipment.com/abrasives
Ash
« Last Edit: July 07, 2015, 03:12:15 PM by AshimotoK0 »
« Reply #34 on: July 07, 2015, 05:30:25 PM »
Hi Ash
We finished with 1200 Wet & Dry prior to primer and between base undercoats
From the read up it sounds as if it would do the job ok,but we are no experts in bead blasting, we did it the old fashioned way with a stanley blade and sore fingers
Keith Snr
« Last Edit: July 08, 2015, 08:33:38 AM by Coppertop1234 »
« Reply #35 on: July 09, 2015, 05:16:23 PM »
Heres a few pics of both projects we are working on
Project 1 (Red)   - Project 2 (Yellow)
Offline Green1
« Reply #36 on: July 09, 2015, 08:35:20 PM »
Bikes look great shame about the blue pipe  ;)
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #37 on: July 09, 2015, 09:24:12 PM »
Hopefully this will be resolved as we have another original exhaust for project 2 which requires re chroming on downpipes. When they go in so will these
Keith Snr
Offline haynes66
« Reply #38 on: July 09, 2015, 09:46:31 PM »
i like blue pipes! it shows the bike is being ridden and not kept in a heated garage somewhere.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline Green1
« Reply #39 on: July 09, 2015, 11:05:15 PM »
I'm sure Ralph will pipe up soon now you've said that on a Brit bike yes a Honda no.  ;)
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #40 on: July 09, 2015, 11:59:03 PM »
There looking sharp Keith. Nice one. I will probably get flamed for this, but I to kinda like blued pipes. Shame they aren't all blued the same though. Guess they aren't double skinned on the F1 then?
Sent from my Nexus 7 using Tapatalk
« Reply #41 on: July 10, 2015, 05:58:41 AM »
Yes, they ARE double skinned on F1, to go blue like that, one cylinder has been running very hot, for a long time, or the inner skin of the pipe has broken up/cracked or spllit allowing hot gases to discolour the outer skin. If it was running that hot, it could damage the piston (weak mixture), if the inner skin has failed, re-chroming will be a waste of money, as it will discolour again.
« Reply #42 on: July 10, 2015, 08:49:19 AM »
Exhaust is from another donor bike which has a fine running engine, so I was informed.
I can only presume in its previous exhaust life it had some engine issues, to cause blueing of pipe,also slight yellowing on No 1 pipe.Personally I think the old engine was out of sync and running hot on the 2 effected cylinders causing discolouration.
I think i will still gamble and have them re-chromed again ,but thanks for comments
Offline Chris400F
« Reply #43 on: July 10, 2015, 11:25:52 AM »
Exhaust on the yellow bike looks like a Motad, in which case pipes would certainly only be single skinned.
« Reply #44 on: July 10, 2015, 01:19:07 PM »
Just got insurance quotes from Bikesure
2 policies both with named riders so we can ride either - £121 each
Mileage 3k per year
Guaranteed value of 4k +£15
Excellent price I think
Keith Snr
