Author Topic: flat spot  (Read 5419 times)
Offline Ashdowner
Re: flat spot
« Reply #15 on: September 01, 2015, 01:38:21 PM »
I put electronic ignition on mine and I'm glad I did because once set it's something you don't have to worry about, and it takes ignition out of the equation when problem solving. Beware though because not all systems are equal. I got the one from David Silver and if I'm tootling along in traffic with my headlight on then my battery does start discharging, so they do have quite a drain on the system.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: flat spot
« Reply #16 on: September 01, 2015, 06:23:37 PM »
Is that correct that Boyers don't use the mechanical advancer?
« Last Edit: September 01, 2015, 06:50:51 PM by royhall »
Offline totty
Re: flat spot
« Reply #17 on: September 01, 2015, 07:02:22 PM »
Some models don't use the mechanical advance.
http://www.boyerbransden.com/microdigitalmicropower.html
Re: flat spot
« Reply #18 on: September 01, 2015, 07:07:24 PM »
 yes,the magnets rotor fits directly onto the center of the advance unit,you have to remove the cam,springs and weights to fit,
the electronics do the advance,set ignition at full advance at 4,500 rpm with a strobe,
its worthwhile checking the plug caps and plug leads as a stronger spark will show any faults,especially in the wet.
