Author Topic: to red \line or not....  (Read 5136 times)
Re: to red \line or not....
« Reply #15 on: June 15, 2015, 09:41:21 PM »
Shouldn't be anywhere near the red at a ton, probably no more than 6,000r.p.m, unless you are VERY undergeared, or in 4th with a slipping clutch!:-S
Offline tom400f
« Reply #16 on: June 15, 2015, 11:02:48 PM »
One red line experience that didn't end well
http://m.liveleak.com/view?i=58b_1432425951
 :P
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
« Reply #17 on: June 15, 2015, 11:07:57 PM »
« Reply #18 on: June 17, 2015, 09:07:15 AM »
Seized solid, the rev counter dropped to zero instantly. May have saved it if he thought to pull the clutch in. You can almost hear the plastic cracking and his wallet opening.  ;D
Offline tom400f
« Reply #19 on: June 17, 2015, 09:57:39 AM »
It has spewed all its oil so an "uncontained engine failure"  ???
1978 CB400F2 Yellow
1995 VFR750FS Red
« Reply #20 on: June 17, 2015, 11:06:20 AM »
Frac that and its newer than my two
Bitsa
« Reply #21 on: June 17, 2015, 11:57:07 AM »
No wonder he was sliding all over, didn't see the oil thought it was just a lockup.  That's one big blow up.
« Reply #22 on: June 17, 2015, 12:20:08 PM »
I can remember back in the days,
 the engine never failed,it was always electrical problems,
 maybe the conrod poking through the cases knocked a wire off ????
 or all the oil underneath was from the generator ,nothing to do with the big hole in the sump!!!
Offline steff750
  • THE POWER OF DREAMS
« Reply #23 on: June 17, 2015, 09:27:17 PM »
Quote
rodney you plonker  :)
