Author Topic: Cb750 dual disk upgrade  (Read 13299 times)
Re: Cb750 dual disk upgrade
« Reply #15 on: June 20, 2015, 11:21:09 AM »
Burro
Sorry its taken a bit of time everything now does but I found one on a axle in the shed if you get into trouble
Bitsa
Offline El__burro
« Reply #16 on: June 20, 2015, 02:34:02 PM »
Thanks Bitsa, I would love to see if you can measure the length of the spacer.
I have bought a pair and hopefully one of them will be a straight fit.
In case I'll pm you about the axle you mentioned.
El__burro
« Reply #17 on: June 21, 2015, 11:15:37 AM »
Burro
Do these help you out?I make the length 17mm width 22mm
Bitsa
« Last Edit: June 21, 2015, 11:25:37 AM by Bitsa »
Offline El__burro
« Reply #18 on: June 21, 2015, 04:14:55 PM »
Do I read
ID 15mm
OD 22mm
L 17mm
El__Burro
« Reply #19 on: June 21, 2015, 05:13:34 PM »
Yep That's as I read it mate
Bitsa
Offline El__burro
« Reply #20 on: June 21, 2015, 05:15:14 PM »
how much do you ask for your collar?
pm if you want.
thanks
el__burro
« Reply #21 on: June 22, 2015, 07:15:34 AM »
Bitsa
Did you find your vernier, or is that a new one mate  ;)
« Reply #22 on: June 22, 2015, 08:33:47 PM »
Trig
Naw a new cheap thing but it seems to do the things I want from it ;)
Bitsa
Offline El__burro
« Reply #23 on: June 23, 2015, 05:42:30 PM »
Latest update, after a busy day so far.
I received the collar and shaved it to 17mm length.
Then fitted the wheel and callipers.
I have followed the instructions as per link in 1st post.
Is the gap in the photo normal?
Also is it all put together properly?
 El__burro
« Reply #24 on: June 23, 2015, 08:11:59 PM »
No when I played with one a while back someone had made spacers to get the caliper vertical exactly the same as the original on the other side otherwise it binds like a barsteward.
Bitsa
Anyone got a working set up you can show him?
Offline El__burro
« Reply #25 on: June 25, 2015, 10:52:06 PM »
i have read the salocal article (in my 1st post) many times but and i cant see where I've gone wrong.
calliper/disk/forks alignment is achieved with a few shims.
In my case i have used 8 (see picture in previous post)
thanks
el__burro
Offline Waggles
« Reply #26 on: June 26, 2015, 10:04:10 AM »
Can you post a pic taken a bit further away? Something doesn't look right in the top pic but I can't quite make out which way the front of the bike is. Could the fork slider be reversed or something?
Offline El__burro
« Reply #27 on: June 26, 2015, 10:52:59 AM »
Here are some more pictures.
I hope it helps you to help me.
El__burro
« Reply #28 on: June 26, 2015, 04:16:52 PM »
The top bkt don't look right to me and don't forget the mudguard bkt  has to to go up against the fork slider first which will take up more space so less spacers.If it were me by now it would be getting on my wick cant think of much more unless I am sitting in front of it sorry
Bitsa
Offline El__burro
« Reply #29 on: June 26, 2015, 08:08:26 PM »
I've tried mounting the fender but it gets worse. (See picture)
I think the main issue is the fork touching the pivot arm.
probably others may have fitted a different caliper arm. (Top one in the picture)
El__burro
