Author Topic: Cb750 dual disk upgrade  (Read 13608 times)
Offline MarkCR750
Re: Cb750 dual disk upgrade
« Reply #30 on: June 26, 2015, 08:19:58 PM »
The arms I used are as below, it could well be that you need these arms.
Suzuki GT250A (Nostalgia)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
Offline El__burro
« Reply #31 on: June 26, 2015, 08:54:24 PM »
I thought so.
Do you have them on both sides I guess,  what about the fender?
El__Burro
Online Bryanj
« Reply #32 on: June 26, 2015, 09:06:05 PM »
They wont fit on the early style fork slider
Offline El__burro
« Reply #33 on: June 26, 2015, 09:08:46 PM »
Mmm from bad to worse.
Offline MarkCR750
« Reply #34 on: June 27, 2015, 07:02:13 PM »
I thought so.
El__Burro
Yes both sides, I'm not fitting a mudguard, I prefer the look without, but you can fit one as shown below, bad luck it appears you may need new forks then? or just stick with single disc.
Sir J.Stewart.
Online Bryanj
« Reply #35 on: June 27, 2015, 07:38:29 PM »
The "mirror image" caliper bracket was originaly a magnesium casting for Honda Racing which was supplied in a kit along with carbs and lots of other goodies.
You can use a standard bracket by maching off the "Lump" that goes against the normal slidetr and using spacer(s) to get the bracket to bolt on the opposite slider in the correct alignment.  If you dont want to do this you need a pair of later forks that can use the bracket you pictured
Offline El__burro
« Reply #36 on: June 27, 2015, 08:38:27 PM »
that picture is so porn.
Offline El__burro
« Reply #37 on: June 27, 2015, 08:44:42 PM »
You can use a standard bracket by maching off the "Lump" that goes against the normal slider.
i thought about this option but not sure if it weakens the arm somehow.
ive been looking online but no success.
what is a decent gap?
starting to see the way out of this.
thanks
el__burro
Online Bryanj
« Reply #38 on: June 28, 2015, 12:25:15 AM »
Machining and spacers is the way that 98% of the early twin brake conversions were done as nobody could afford the Honda Kit!!!
Offline El__burro
« Reply #39 on: June 28, 2015, 12:36:07 AM »
i guess thats my same route.
just studying on a spare one ive got.
probably shaving up to the 4th shim could do.
thanks
el__burro
« Last Edit: June 28, 2015, 01:08:37 AM by El__burro »
Online Bryanj
« Reply #40 on: June 28, 2015, 01:16:43 PM »
Those look like spring washers, you would be better off using flat ones or measure it and get a spacer made
Offline El__burro
« Reply #41 on: June 28, 2015, 01:21:43 PM »
Yeah I know, it was just to get an idea.
I have bought enough flat washers now.
Tomorrow I'll be starting to shave the "lump" off the calliper arm (the red bit)
El__ burro
« Last Edit: June 28, 2015, 01:24:34 PM by El__burro »
Online Bryanj
« Reply #42 on: June 28, 2015, 05:25:40 PM »
You should not have to shave those bits, I meant the lump under the bolt head that holds it to the leg. Try adding slightly more spacer so that those red bits just clear
Offline El__burro
« Reply #43 on: June 28, 2015, 08:03:34 PM »
what lump under the bolt head?
Do you mean the part in red in the pictures?
thanks
el__burro
« Last Edit: June 28, 2015, 08:34:16 PM by El__burro »
Online Bryanj
« Reply #44 on: June 29, 2015, 04:33:35 PM »
No the one on the bracket directly under the bolt head
