Author Topic: Felt washer 500 four carbs  (Read 1083 times)
Offline Noelia
« on: July 17, 2015, 10:30:40 PM »
Hi all,
Any idea where can I find this? I need two
I'm rebuilding my carbs and one is missing and second one has expanded and won't fit in the carb.
Thank youuu
Re: Felt washer 500 four carbs
« Reply #1 on: July 17, 2015, 11:41:16 PM »
Don't think there is a part number. The size is OD 12mm, ID 10 mm and 2mm thick when new. Try this link and you will have to cut them down (Cheap option)>>> http://www.ebay.co.uk/itm/20-Felt-Washers-16mm-O-D-X-4mm-I-D-X-2mm-Thk-/131547304092?pt=LH_DefaultDomain_3&hash=item1ea0d4909c
Offline corromant
« Reply #2 on: July 18, 2015, 07:39:59 AM »
Buy a piece of felt of the thickness you want & some hole punches.
Born again SOHC owner
Offline Noelia
« Reply #3 on: July 20, 2015, 10:32:43 PM »
Got a punch set and felt sheet! On its way right now. Once I have them all back together how do I sync them??
