Author Topic: Fuelling?  (Read 737 times)
Offline wolfheze
Fuelling?
« on: August 02, 2015, 06:38:40 PM »
Hi. Have got a problem with my 550. It starts and runs perfectly except for a flat spot which only shows itself if you try to sit at half throttle after rolling off from around three quarters to flat out. It accelerates through the gears fine and will run ok on a half throttle as long as you haven't  rolled off first. It's a K2  with standard exhausts and as far as I know correct jet sizes and float heights. It's  not a massive issue just slightly irritating and would be reluctant to start messing with it without a fairly good idea what the cause is.
