Author Topic: anti seize grease  (Read 1231 times)
Offline haynes66
anti seize grease
« on: August 07, 2015, 09:31:33 PM »
what do you use on your stainless/ali bolts? i've just finished the last of my wurth AL1100 grease but at £25 a tin i'm looking for a cheaper alternative. i didnt pay for my last lot as i used to be a wurth rep so i had a lot of freebies for my shed over the years!
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline Green1
Re: anti seize grease
« Reply #1 on: August 07, 2015, 11:23:35 PM »
I'v started using Corrosion Block from ACF50 and it doesn't go hard like coppaslip when in contact with water.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #2 on: August 08, 2015, 10:33:04 AM »
It's not just the threads that seize, it's the area under the screw head where it meets the aluminum casting, so put some copperslip there too.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: August 08, 2015, 02:07:40 PM »
I'm no alchemist... but what Mike says is what I've been told ... ie you need to 'seal the head' & stop moisture / water getting to the threads...
Ask me in 5 yrs.. I've gone the Copperslip route with Oddjob.
Simon
Offline Green1
« Reply #4 on: August 08, 2015, 03:10:03 PM »
The garage that drilled out the seized bolts in my Guzzi used a silicon grease as they have known coppaslip to go hard on the threads making it hard to remove bolts.
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
