Author Topic: Starter solenoid  (Read 2516 times)
Offline Green1
Starter solenoid
« on: August 09, 2015, 08:36:48 PM »
Are starter solenoids repairable mine seems to have stopped working?
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: Starter solenoid
« Reply #1 on: August 09, 2015, 08:39:46 PM »
Possibly, but they're not expensive to buy, pattern ones (Sorry Bitsa!) are less than a tenner, and you could mess with your old one all day, and it might not hold together again!
« Reply #2 on: August 09, 2015, 08:42:01 PM »
Not worth the hassle as you can get a new one for under a tenner >> http://www.ebay.co.uk/itm/solonoid-solenoid-Starter-Relay-Honda-CB550-1974-1980-/161187088927?pt=LH_DefaultDomain_3&hash=item25877fca1f
Fit these for years and never had a problem yet
Offline Green1
« Reply #3 on: August 09, 2015, 08:45:28 PM »
That's what I thought I looked at that one but couldn't bring myself to buy it without hearing Don't Touch Pattern Parts.  ;D
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #4 on: August 09, 2015, 08:49:23 PM »
Most pattern parts are put in OEM bags and boxes these days  ;D ;D
Offline Green1
« Reply #5 on: August 09, 2015, 08:55:17 PM »
That is very true it also goes the other way with genuine parts in pattern boxes.
My brother used to work for a well known now defunct car parts place it wasn't unusual to find Bosch coil packs in after market boxes.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline Dave_Canada
« Reply #6 on: August 18, 2015, 09:35:55 AM »
Usually the high current contacts get damaged by arcing or the moving contact piece jams. Pretty easy to service, half an hour and a flat file is all you need. Take the contact end off, remove the nuts on the studs and push the contact studs out. File the flat. File the moving piece flat. Clean out any crud, reassemble. I can't exactly describe the process but it once you open it up it will be easy to see what you need to do.
If the coil bit is jammed, it's toast. This is not really repairable.
Offline Green1
« Reply #7 on: August 18, 2015, 08:20:27 PM »
Thanks Dave I'll look at it when I find the time  ::)
I bought the one listed above as a temp fix and it looks a bit to Chinese for my liking.
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #8 on: August 18, 2015, 11:07:34 PM »
Mick, you are sounding like Bitsa in your old age ;D ;D ;D
