Author Topic: Gel Battery  (Read 3566 times)
Gel Battery
« on: August 10, 2015, 05:36:47 PM »
Had a Gel battery delivered that had been dropped and has a hole in the top. The question is: can this battery be used ?
Nothing is leaking out of it and it is taking a charge. Just not sure what is inside these things.
Offline Green1
Re: Gel Battery
« Reply #1 on: August 10, 2015, 07:21:30 PM »
Send it back.
I wouldn't trust the fumes from it the will try to corrode everything.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: Gel Battery
« Reply #2 on: August 10, 2015, 07:33:10 PM »
Send it back.
Mick
It is a freebee as it will cost more to send back than what it is worth. Was thinking of filling the hole up with silicone but, not really sure what is inside as never cut one up before.
Offline Green1
Re: Gel Battery
« Reply #3 on: August 10, 2015, 07:38:16 PM »
How big is the hole Trig can you melt the case with a soldering iron?
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Re: Gel Battery
« Reply #4 on: August 10, 2015, 07:43:03 PM »
yes it can be melted but, don't know how dangerous it will be.
Offline Green1
Re: Gel Battery
« Reply #5 on: August 10, 2015, 07:44:38 PM »
What are you planning to melt it with a blow torch.  ;D
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Re: Gel Battery
« Reply #6 on: August 10, 2015, 07:53:32 PM »
There is a product called Petro Patch which as well as fixing leaky fuel tanks claims to be good for repairing battery cases as well, probably worth a try?
Offline steff750
  • THE POWER OF DREAMS
Re: Gel Battery
« Reply #7 on: August 10, 2015, 08:54:50 PM »
DO NOT use  any heat what so ever near a battery IT WILL EXPLODE the fumes are very inflammable , if you are that desperate crack on
fill it with whatever you like, don't forget its sulphuric acid now not distilled water lol
but I have been on a bike when the battery has exploded it was so loud I thought I had blown a tyre ,didn't find the fault till weeks later. blew the side off the battery it can get very messy and you wont see the corrosion until its too late
Offline Green1
Re: Gel Battery
« Reply #8 on: August 10, 2015, 09:03:29 PM »
I solder banks sub c batteries together to repair cordless drill batteries they haven't exploded yet. They can get hot if you try to rush it though
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Re: Gel Battery
« Reply #9 on: August 10, 2015, 10:12:48 PM »
I do that too.  those cordless batteries are bloody pricey.
Offline tom400f
Re: Gel Battery
« Reply #10 on: August 10, 2015, 10:52:12 PM »
Don't know how gelatinous the electrolyte is but how about a piece of perspex plate cemented down with some silicon mastic?
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Re: Gel Battery
« Reply #11 on: August 10, 2015, 10:55:44 PM »
I'd use Sticks Like Sh*t.   It bonds far better than silicon.
Offline Norniron
Re: Gel Battery
« Reply #12 on: August 10, 2015, 11:00:11 PM »
Agreed silicone is crap!
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Gel Battery
« Reply #13 on: August 10, 2015, 11:38:21 PM »
.... reading all the above Trig, & in light it's a freebie I'd bin it & move on.
Too many times in my life I've 'made things do' only for it to come back & bite me on the arse....it's a bike; they fall over, have spills (!!!!) .... you don't need a leaky battery adding to your woes.
S
« Last Edit: August 10, 2015, 11:42:17 PM by Lobo »
Re: Gel Battery
« Reply #14 on: August 11, 2015, 08:45:21 AM »
Was going to use it on a pre-restored bike. Interesting links>>> https://www.youtube.com/watch?v=u4Xhmnmb_2U
https://www.youtube.com/watch?v=rvhpXxesNr8  Looks like you can drill a hole and still use it ;D
