Author Topic: Headlight retaining bolts  (Read 1884 times)
Offline ted_paper
« on: August 30, 2015, 02:54:46 PM »
Hi, this is probably a daft question. I've just got round to removing my tax disk holder which was held on via the side reflector/ headlight bolt. When trying to screw the bolt back in, it just pushes straight into the headlight shell. Is it possible that  I might have  disturbed a retaining nut in the  shell?
Re: Headlight retaining bolts
« Reply #1 on: August 30, 2015, 03:05:20 PM »
Yes. quite likely, you'll need to remove the bulb/reflectot assy from the shell to locate the nut, it's often got some geen wires attached to it for the earthing points. Hold  it in place while you replace the bolt, refit the bulb/reflector assy. job done:-D
Offline Greg65
« Reply #2 on: August 30, 2015, 03:06:59 PM »
Your too fast Julie, just looked up the info and you were there.
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
Offline Bodd
« Reply #3 on: August 30, 2015, 03:07:49 PM »
The nut is on a plate that slides into a slot on the inside of the headlamp shell, maybe it's been pushed out of the slot, you can see what I mean about 3/4 of the way down this page of my restoration/cafe build.
Offline ted_paper
« Reply #4 on: August 30, 2015, 03:12:54 PM »
Cheers Guys, that's a rainy Bank Holiday Monday excuse for a couple of hours in the garage!
« Reply #5 on: August 30, 2015, 07:38:15 PM »
 ;D ;D ;D ;D ;D ;D Yes Greg, if there is quick, girlie way of doing something on these bikes, I have found it through trial and error and the benefit of having small hands
« Last Edit: August 30, 2015, 07:45:06 PM by Nurse Julie »
« Reply #6 on: August 30, 2015, 08:22:16 PM »
If you put some glue behind those nuts they won't fall off next time.
Offline ted_paper
« Reply #7 on: August 31, 2015, 12:12:40 PM »
Mike - Just relocated the nut now...wish I'd have read  your post first!
