Author Topic: Steering lock  (Read 1481 times)
Offline shifter
Steering lock
« on: October 03, 2015, 03:10:13 AM »
Can anyone advise on removal and replace new  steering lock  ,ie - do l drill existing rivet by dremmel / drill out etc ?Also I'm not clear the procedure of fitting lock by means of the rivet ...
" RIDDEN NOT HIDDEN"
 Moto morini 250 2c
Cb200
S90
Offline totty
Re: Steering lock
« Reply #1 on: October 03, 2015, 09:36:03 AM »
Rivet pulls out, twisting it helps, and it taps in. If you don't have the key you'll need to drill out the lock barrel.
Offline shifter
Re: Steering lock
« Reply #2 on: October 03, 2015, 12:04:43 PM »
Many Thanks Totty , I wasn't quite sure how the rivet was fitted, big clout with hammer  eh .. Cheers ..
 Moto morini 250 2c
Cb200
S90
Offline Chris400F
Re: Steering lock
« Reply #3 on: October 03, 2015, 12:06:05 PM »
If you haven't already got a replacement lock yet I got mine from here:
http://www.ebay.co.uk/itm/Handlebar-Lock-Lenkschlos-Steering-Lock-Steering-Lock-For-Honda-Kawasaki-/231388905798?pt=LH_DefaultDomain_3&hash=item35dfda8146
Drilling out is a fairly simple operation, there are probably threads on here that cover it.
Fitting instructions are available on request from the eBay seller. They don't tell you much that you can't find elsewhere
but I seem to remember something about having to turn the lock once the middle is drilled out to free a locating pin.
Offline shifter
Re: Steering lock
« Reply #5 on: October 03, 2015, 09:33:29 PM »
Thanks chaps for the info , lock's on its way Chris,
 Moto morini 250 2c
Cb200
S90
