Author Topic: Velocity stacks / Air filters  (Read 6054 times)
Offline El__burro
« on: October 15, 2015, 05:10:26 PM »
I reckon that the poor running (and even at idle) of the engine could be caused by the lack of air filters.
I have removed it and just kept the cones that look like velocity stacks.
Today I have covered them with a t shirt cutting and at times i felt like it improved the idling.
I don't want to reinstall the old filter box but I am not sure if this solution could work somehow.
Shall I opt for velocity stack or a set of these spongy filters?
El__burro
Offline haynes66
Re: Velocity stacks / Air filters
« Reply #1 on: October 15, 2015, 08:01:49 PM »
i think it looks fine as it is!!
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
« Reply #2 on: October 15, 2015, 08:58:22 PM »
Nothing wrong with T shirt filters, go for it.
« Reply #3 on: October 16, 2015, 08:49:37 AM »
Now that is inventive, would never have thought of that one.
Offline El__burro
« Reply #4 on: October 16, 2015, 10:01:42 AM »
My mixture screw is all closed. How many turns should it be set to?
El__burro
« Reply #5 on: October 16, 2015, 10:02:45 AM »
varies by exact model of bike and carb
Offline El__burro
« Reply #6 on: October 16, 2015, 10:04:36 AM »
It's a cb750 k2 with stock carb (no airbox). Surely all closed is not right is it?
« Reply #7 on: October 16, 2015, 10:33:42 AM »
my thoughts are tee shirt cloth is to restrictive,
 I would experiment with tights,
 maybe one or two layers,
not the thick woolly ones !!!!
see this link
http://www.speedwaybikes.com/handbook/sh_ch10.htm
« Reply #8 on: October 16, 2015, 11:59:01 AM »
All closed is not correct, try about 2 1/8 turns out for a start
Offline El__burro
« Reply #9 on: October 16, 2015, 01:58:59 PM »
thanks,
that is a nice read.
Panty hose or nylon stocking is the way to go..
over the filter I mean.
Actually the screw that is all tight, is the throttle stop (according to the diagram) the one in copper visible in the picture.
I need to find the air mix screw and work out different settings.
thanks
el__burro
« Last Edit: October 16, 2015, 02:07:16 PM by El__burro »
« Reply #10 on: October 16, 2015, 03:28:01 PM »
These might help
Offline El__burro
« Reply #11 on: October 16, 2015, 04:37:27 PM »
thanks Dennis,
actually the problem of poor idling is caused by fuel and not filter or air starvation.
when I feed the 2 sets of carbs individually it roars like a lion.
Probably there is a blockage in the connections between the carbs caused by the "rubbish" i found in the tank.
Is there an easy fix that doesn't require carbs removal?
el__burro
Offline El__burro
« Reply #12 on: October 19, 2015, 03:05:52 PM »
I've removed the carbs just to figure out that there is no direct connection between 1-2 and 3-4.
My question is, how do I feed all the carbs at once.
I have one fuel pipe feeding 1-2 and the other 3-4
how this works exactly
thanks
el__burro
« Reply #13 on: October 19, 2015, 04:59:48 PM »
This shows the fuel lines on my CB750F1, hope it helps, here's a thread on the same subject. http://forums.sohc4.net/index.php/topic,76367.0.html
« Last Edit: October 19, 2015, 05:09:37 PM by Spitfire »
Offline El__burro
« Reply #14 on: October 19, 2015, 09:01:26 PM »
maybe I need to connect each fuel pipe to both carbs.
correct?
