Author Topic: HM323 Update  (Read 39184 times)
Re: HM323 Update
« Reply #120 on: April 14, 2017, 06:06:05 PM »
Quote
And louder than I expected.
Then maybe the balance tubes are not well connected.
Re: HM323 Update
« Reply #121 on: April 14, 2017, 07:53:38 PM »
Quote
I vaguely recall having the same issue when I first took my exhausts off my brand new 500, I turned out I had re-installed them incorrectly, one bracket goes behind the footrest hanger and one in front of it, I put them together and this caused the back end to miss align so much it was a real struggle to get the balance pipe on, once I figured out what I'd done the were fine again. Check the position of the brackets is my advise.
Same here. To check your brackets the photos in this post are very helpful: http://www.sohc.co.uk/index.php/topic,10228.msg73340.html#msg73340
Re: HM323 Update
« Reply #122 on: April 15, 2017, 06:58:05 AM »
Well they're on. A cup of tea helped followed by some more bending and twisting of the lower bracket. Not perfect and the bracket is a bit of a mess to look at, but at least I've a bike on the road. And louder than I expected.
Done it, and the set I fitted lined up perfect with both brackets on the front of the hanger. The PO had tweaked them that much, the pipes would not line up with the brackets on the right way.
Offline Seabeowner
Re: HM323 Update
« Reply #123 on: April 18, 2017, 07:47:02 PM »
And I thought I had a problem putting the pipes on. Take a look at the 10th pic.
http://www.ebay.co.uk/itm/HONDA-CB500-FOUR-KO-1971-Historic-Vehicle-/182533926543?
Mine are on OK. But I will buy a new LHS lower bracket, unless anyone has one here.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
