Author Topic: Spoke set suppliers  (Read 1440 times)
Offline r1_pete
Spoke set suppliers
« on: November 17, 2015, 12:45:32 PM »
Does anyone know a UK supplier of spoke sets.
I'd like galvanised steel to match the back wheel which is in good order, there seems to be lots of suppliers in the USA at about £35, but postage is expensive.
Cheers.
Pete.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Re: Spoke set suppliers
« Reply #1 on: November 17, 2015, 02:33:15 PM »
David Silver spares do a decent value set for the 750...
Offline r1_pete
« Reply #2 on: November 17, 2015, 03:39:58 PM »
Cool thanks, found them, under W for Wheel, I was looking under S for spokes  :-[
1971 CB450
« Reply #3 on: November 17, 2015, 06:09:46 PM »
Theirs are good but the nipples are not yellow chromate finish to be like standard OEM. You can treat them yourself though, if you are an anorak like me. Gateros plating sell the correct solution to do it.
« Reply #4 on: November 17, 2015, 06:23:18 PM »
Ash - do you have a link to the gateros kit - is it a chemical dye process?
« Reply #5 on: November 17, 2015, 06:37:32 PM »
it's a chemical process as would have been used if they had been done by the manufacturer. It's a simple dip no electricity but it contains chromic acid and hydrofluoric acid so keepout of the way of the wife and little 'uns and don't let Nurse Julie know you are using it
Fully degrease nipple first .
http://gaterosplating.co.uk/Replacement-Items.php
scroll down to
Yellow/gold passivate, enough to make 9 litres of passivate
£9.99
Offline MeilakJ
  • Life is what you make it!!
« Reply #6 on: November 17, 2015, 08:29:26 PM »
Hi Pete ,
Would the below help ? and they are yellow. I got mine from Andy Cepok and if you order to him directly you can get a 5 % discount.
John
http://www.ebay.co.uk/itm/Honda-CB-750-Four-Speichensatz-Gelb-verzinkte-Nippel-Vorderrad-spoke-front-Wheel-/291242786811?hash=item43cf6c3ffb:m:mWs5VyCePVrzxU8hcGagRGQ
