Author Topic: Help with cb550 yokes  (Read 1066 times)
Offline harris24982
« on: December 06, 2015, 12:25:17 PM »
Hi
I recently picked up a 1976 cb550 project and am having trouble finding a set of yokes to fit, was wondering if anyone knows of any other makes and models that the yokes would fit from?
don't mind If the forks are a different size as the bike is a custom and would like to run a drum brake anyway
thanks
Re: Help with cb550 yokes
« Reply #1 on: December 07, 2015, 06:35:17 AM »
About the only drum brake that would fit without  a lot of machining would be the CL450 1970-73 and the only place you will get those bits is the USA
Offline matthewmosse
« Reply #2 on: December 07, 2015, 07:56:49 AM »
Yokes wise cb250superdream ones slot right in.
Offline harris24982
« Reply #3 on: December 11, 2015, 04:48:33 PM »
thanks for that, think i'll give the cl450 wheel a miss bit pricey to bring over
i'll give the cb250 a try think I might have one somewhere
can anybody tell me the length of the stem on the original yokes? I belive I've found the width online as 26 upper and 30 lower but can find a length mentioned anywhere
