Author Topic: CB500/4 K0 brown touch up paint  (Read 4466 times)
Offline Menno
  • www.tanklackieren.de
Re: CB500/4 K0 brown touch up paint
« Reply #15 on: January 04, 2016, 01:13:45 AM »
Well, touching up candy is always very difficult. Even when I look at your nice candy garnet brown 500 I can see a difference in the sidepanels and the tank.
They were originaly not a set were they?
If the chips are realy tiny I would advise just to leave it like that. Quite often a touch up might look very amateuristic especialy when the paint is not 100% identical.
Call it verdigris. (I used a translator on this word.. Is it correct? I mean aged)
However: this is important.. is the pant chipped off all the way to the bare metal or is the basic layer still there.
If the basecoat is still there I could send you some candy garnet brown in a touch up bottle. You could try it with a very small pencil.
It would be: touching up and immediately whiping off. The trick is to leave just enough pant sticking to match the surrounding paint.
And you would need: fingerspitzengefühl.... (sensitivity just doesn't translate that right)
« Reply #16 on: January 04, 2016, 07:37:00 AM »
Quote .. ("I used a translator on this word.. Is it correct? I mean aged")  ...............   Patina  ;)
BTW -- hoping to get my CB500K0 Candy Jet Green Tank and panels off to you this week Menno .. 1000 apologies for the delay .... Ash
« Last Edit: January 04, 2016, 09:31:26 AM by AshimotoK0 »
« Reply #17 on: January 04, 2016, 11:17:18 AM »
verdigris = the green colouring on aged copper.
Steve
2022 Tiger Sport 660
Offline ST1100
« Reply #18 on: January 04, 2016, 05:38:16 PM »
You could try it with a very small pencil. It would be: touching up and immediately whiping off.
When fixing pebble-chips on car hoods (err... zis is a UK forum, so zis is called a bonnet then  ;) ), I use toothpicks to just fill and level the the paint layer with a tiny drop (won't work if its down to the metal or already corroding)
Once dry very fine wet-sanding, polish, etc...
BTW: also I'm still due in shipping my K2 tank and side panes...  :-\
Got swamped with other issues and still searching for a really rigid carton... don't want to have that thing all banged up...
STOC #637
