Author Topic: 1977 CB550  (Read 28051 times)
Offline Valentinik
Re: 1977 CB550
« Reply #105 on: August 13, 2016, 10:31:16 PM »
I started rebuilding the forks today. Got the new seals installed and everything In place but have A question.
What torque should the 8mm Allen head oil lock bolt at the bottom of the fork be tightened to? And should thread lock be used on it?
I did take a look in the factory manual but the bolt descriptions weren't clear to me.
Mike
Re: 1977 CB550
« Reply #106 on: August 14, 2016, 12:00:13 AM »
Just do it up tight is enough and only use threadlock if you want it to be a swine to change seals again BUT do make sure the copper washer is in good nick
Offline Valentinik
Re: 1977 CB550
« Reply #107 on: August 14, 2016, 09:37:41 AM »
Thanks Bryan, I will get some new washers fitted before they are installed.
Offline Valentinik
Re: 1977 CB550
« Reply #108 on: August 21, 2016, 08:49:34 PM »
Spent some time over the weekend, getting the forks on and the partially built up engine I'm the frame. I can get on with finishing the engine build off now.
Mike
Offline Valentinik
Re: 1977 CB550
« Reply #109 on: August 21, 2016, 09:03:44 PM »
A question, I have a new gasket for the clutch cover, do I need to put and hylomar on this gasket or should it be fitted dry?
Mike
Re: 1977 CB550
« Reply #110 on: August 21, 2016, 09:26:03 PM »
No sealant needed, although some people smear the gasket with grease, helps stop it sticking and tearing if you need to do any further work inside.
Offline Valentinik
Re: 1977 CB550
« Reply #111 on: August 21, 2016, 09:27:55 PM »
That's a great tip, thank you.  :)
Mike
Offline Valentinik
Re: 1977 CB550
« Reply #112 on: August 26, 2016, 08:58:52 PM »
I got my tank back today. Im really pleased, it looks flawless. The colour may not be to some peoples taste but its exactly what I wanted.
Mike
Offline Valentinik
Re: 1977 CB550
« Reply #113 on: September 06, 2016, 11:19:33 PM »
I got the cylinder head installed tonight along with the cam.
I had planned on fitting the rocker cover. When I removed the head I noticed the 6 rubber blanking caps had been installed with some sort of clear sealant. Do they need any sealant fitted or should they just sit in place?
Mike.
Re: 1977 CB550
« Reply #114 on: September 07, 2016, 05:56:03 AM »
New rubbers should not need sealant but pattern ones sometimes need A VERY SMALL AMMOUNT.
DO READ THE MANUAL CAREFULLY BEFORE FITTING THE COVER or you WILL bend valves
Offline Valentinik
Re: 1977 CB550
« Reply #115 on: September 07, 2016, 08:39:18 PM »
Thank you Bryan.
I must admit I forgot to order new seals up to this point. Is it possible to re-use them or is it wise to replace them?
Mike.
Re: 1977 CB550
« Reply #116 on: September 08, 2016, 08:13:44 AM »
Depends how lucky you feel, 80% of the time you can reuse the other 20% it leaks more oil than the Torrey Canyon
Re: 1977 CB550
« Reply #117 on: September 08, 2016, 04:42:35 PM »
 Its not as old as i am and yes the RAF did bomb it to set the oil on fire but repeatedly missed!!!
Offline Valentinik
Re: 1977 CB550
« Reply #118 on: September 16, 2016, 09:17:43 PM »
I got the wheels back from the wheel builders today so spent the evening reasembling them and fitting them.
A question, I couldn't see in the manual ( I may be being stupid) the torque spec for the bolt behind the steering stem bolt. Can anyone tell me what the spec is?
This one:
Mike
« Last Edit: September 16, 2016, 09:43:40 PM by Valentinik »
Re: 1977 CB550
« Reply #119 on: September 16, 2016, 09:38:13 PM »
Its a pinch bolt, pinch it up but, not too tight ;)
