Author Topic: Billet fork tops and parts  (Read 2144 times)
Offline captaink
  • Old racers never die. ' they just go faster '
« on: January 10, 2016, 05:46:08 AM »
Hi all,
Having recently acquired a complete GL1000 fork assembly for fitting to my CB750 frame.
Rather than using the original fork top which will require major surgery to look good I was looking for a better looking billet one.
Any suppliers of these in the UK. ? or have I got to look in the USA ?
Any assistance appreciated
Also on stripping the forks an ally sleeve, correct part name oil lock piece was missing...  has anyone got one spare ?
I would also want to replace the fork top nuts for something better looking ,any suggestions ?
Regards
Keith
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Offline Orcade-Ian
    • Older Vehicle Web
Re: Billet fork tops and parts
« Reply #1 on: January 10, 2016, 01:19:13 PM »
Hi Keith,
Just looking at my Haynes manual for 75 to 79 GL1000, I can't see a part labelled 'oil lock' but being a Haynes that doesn't mean anything!  Are you referring to the alloy sleeve with a taper at one end that the damper tube fits into?  Can you take a pic of tother one as I have a suspicion it's fitted to other forks too, including 350 and 400 fours.  I certainly have a spare for those if they are the same size.  Alternatively I could knock one up on the lathe if you supply accurate dimensions.
Ian
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #2 on: January 10, 2016, 01:34:30 PM »
Just found the part in the 400/4 parts list described correctly, unlike Haynes, as 'piece, oil lock' with part number
51432-369-000. Is that your part number?
Checked my early 350/4 parts list and they are a different setup, apologies to anyone if I misled you by saying 350 and 400 are the same - they ain't.
Ian
Just found your part number for GL1000
51432-371-003
So they are different size but similar in appearance
« Last Edit: January 10, 2016, 01:55:50 PM by orcadian »
« Reply #3 on: January 10, 2016, 02:36:44 PM »
You could try this guy on .net in the US:  http://forums.sohc4.net/index.php/topic,150982.0.html
Steve
2022 Tiger Sport 660
Offline yozzer74
« Reply #4 on: January 10, 2016, 02:40:05 PM »
I have seen some billet yokes on eBay that some one makes in UK .steering stem nuts there's ttr 400 that does them he's a member on here . 15 dollars and he does some nice preload adjusters for forks that look good .he does have a web site don't no if you have seen it .
Offline yozzer74
« Reply #5 on: January 10, 2016, 02:43:00 PM »
If you have to buy in US dime city do them I've ordered off them .there good to deal with
Offline matthewmosse
« Reply #6 on: January 10, 2016, 05:34:03 PM »
If he's still going then Malcolm Sheperdson @ Malarkey engineering in Bishops Castle was making billet yokes back when I did work expirience there.
