Author Topic: Smokey Exhaust CB500  (Read 1422 times)
Offline Honda Al
« on: January 24, 2016, 01:09:27 PM »
Hi everyone,
Having sorted out the sticking clutch problem, after a road test I noticed that the Left exhaust is smokier than the right. This has probably been covered before, but does anyone have any suggestions as to why that is? Piston rings or fuel?
Also I noticed that a white vapour/steam is coming from the breather pipe. You can see this on the picture circled in red. I know the pipe shouldn't end there but the PO routed it along the bike to the rear fender. I'll be moving that at some point!
Many thanks, Alan
I love a Honda. Proud father of a 2000 Honda CBR929 Fireblade and 1972 Honda CB500 K1. Oh, and two children!
Offline Honda Al
Re: Smokey Exhaust CB500
« Reply #1 on: January 24, 2016, 01:27:49 PM »
Oh, my question about the breather pipe was is that normal having never owned this type of bike before?
« Reply #2 on: January 24, 2016, 02:17:08 PM »
there is a certain amount of  breather vapour,
 as your bike has been stood,and idle,just ride it around,check the oil  stays clean,
 don't thrash it,but use it when it get warm,
it could be the rings need a little running,they may be sticky in the pistons,
or the bores may have slight corrosion ,
let it settle down,and see what happens
Online Bryanj
« Reply #3 on: January 24, 2016, 04:52:54 PM »
2nd that, run it 500 miles keeping a very good eye on oil level then change oil and filter. If smoking reduces/disapears change every 1500 or annually
« Reply #4 on: January 24, 2016, 05:18:09 PM »
+1 with Bryan. The breather always smokes when the bike has got hot, it is telling you that it wants to go out for a ride  ;D ;D
Offline Honda Al
« Reply #5 on: January 24, 2016, 06:00:47 PM »
Thanks guys. I'll be back in 500 miles and asking for your advice if it's still smoking!  ;)
