Author Topic: Values K0 vs K1 ?  (Read 1582 times)
Offline paulbaker1954
Values K0 vs K1 ?
« on: February 05, 2016, 07:10:25 PM »
Just curious - my bike (frame number 1040871) is I believe a K0 (engine number also starts with 1 but dont have it with me).
Is there any truth that K0s ar worth more than K1 or K2?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Values K0 vs K1 ?
« Reply #1 on: February 05, 2016, 07:15:04 PM »
If frame and engine start with 10...... it is a KO, Everything K0 is worth more than K1 or K2, as it is the first of the model. If it is a UK K0, then the value is even more.
« Last Edit: February 05, 2016, 07:25:46 PM by Trigger »
« Reply #2 on: February 05, 2016, 07:37:43 PM »
Thanks that's helpful ask it happens it's a us import but I guess you can't have everything 😄😄
« Reply #3 on: February 05, 2016, 07:42:19 PM »
The one in the picture is a UK unit. The USA have two values as the early ones came with a flat crank case.
« Reply #4 on: February 05, 2016, 08:08:54 PM »
This is the square crankcase...K0's (first editions) are generally more valuable / collectible.
« Reply #5 on: February 06, 2016, 12:26:09 AM »
Can you clarify what you mean by square crankcase
« Reply #6 on: February 06, 2016, 08:01:30 AM »
Look at the first image above, then compare to the upper crankcase on your bike. That should explain..first ~2300 or so 500 k0's had this feature (we think).
