Author Topic: DIY engine painting..help!  (Read 5460 times)
Offline orangepeelneil
« on: February 19, 2016, 05:38:58 PM »
Hello everyone,
Sure this has come up loads.
Looking for ideas/options for DIY painting my engine on a budget (without taking it to bits)  whilst the frame is away being powdercoated.
The bottom end looks like it has been painted before and is started to come away(original finish?) whilst the top end is pretty dirty, which I've started to clean it up, but the black muck is pretty tough.
I think I would like to keep it silver.
How best to approach this? I guess prepartion is the key (literally!! for the painting)
Do I fully clean and degrease (with e.g a toothbrush and....?)  then mask, primer and spray.
If so which products and process do members recommend?
Not having much luck with the cleaning so far...
Many thanks in advance
Cheers Neil
Re: DIY engine painting..help!
« Reply #1 on: February 19, 2016, 06:25:39 PM »
There's lots of threads on here with lots of varying views.  I used Hammerite Smooth Silver rattle cans on my 750k2. Prep wise, I have done a few full engines without stripping them (my k2 was fully stripped through) and have decreased with your choice of degreaser (I used petrol) then used my favorite resto tool - rotory wire brush in  drill. You can get a full set of varying shape and sizes on ebay. When using on the crankcases, 'blunt' the wire brush first be using it on some steel. USE SAFETY GOGGLES because the wires can fly off sometimes. And obviously make sure that the engine holes are masked properly. Have done 500 miles since resto - albeit in good weather - and finish is as original and mint.
Offline Mike on a bike
« Reply #2 on: February 19, 2016, 07:16:31 PM »
I'm not a complete idiot.....some parts are still missing.
Offline Chris400F
« Reply #3 on: February 21, 2016, 02:56:00 PM »
I have used Hammerite Smooth on various things but never thought of using it on an engine. I can't find any figures as to how heat resistant it is but if you say it works then that sounds fine to me. Did you use any sort of primer or just spray on to bare metal? (Normally for using on non-ferrous surfaces they recommend using their Special Primer). Thanks.
« Reply #4 on: February 21, 2016, 03:36:15 PM »
Chris
I didn't use primer - sprayed straight onto crankcases. I also sprayed head and barrel as well. I remember researching subject of what paint to use on the forum (and/or .net forum) before making a decision so there must be some threads discussing colour match and heat related info knocking about. I seem to remember that some people cured the paint in an over as well.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #5 on: February 21, 2016, 07:59:57 PM »
I have used Hammerite silver smoothrite in spray cans on many engines, the first being my 350/4.  This has been in use for over 10 years and still looks great.  I cleaned all traces of original crap and paint and scrubbed it up with those stainless wire wool scrubbers, then etch primed with Upol acid etch 8, just a thin coat, then on with the Smoothrite.  I removed some of the visible bolts a couple at a time and sprayed around where the bolt head sits, replated (zinc kit) the bolts and refitted.  I have a stock of spare bolts to make it easier.  A couple of years into use and I had a carb leak fuel over the top case which sat for a while before I discovered it and it cleaned off without a problem on the finish.
I am doing the spare 350/4 engine and another 400/4 at the moment but both of those were completely stripped.
As usual they are featured on my site:
www.stallard-engineering.co.uk
Regards,
Ian
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #6 on: February 22, 2016, 09:07:42 AM »
What ever you use, the cases must be completely freeze, dirt and flake free. Personally I got a great finish with Simoniz Aluminium Engine Enamel. If you can cure it in the oven it gives a really tough finish.
Sent from my HTC Desire 510 using Tapatalk
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Lynx
« Reply #7 on: February 22, 2016, 09:10:16 AM »
Petrol and a tooth brush is best for getting thick grease off. Do it in the road as to not stainless your drive 😉.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline masonmart
« Reply #8 on: February 22, 2016, 05:51:39 PM »
If you want to do a quality job rather than a short term one then the only way to do it is to strip down the engine completely and blast it. Soda blasting has the advantage of not possibly leaving grit in passageways etc., but bead blasting is the best quality finish for painting or for just taking bare alloy of the barrel and head down to a lovely matt finish without paint. It's a pain but you have to be very careful about closing of any oilways to avoid getting grit in. Blind threaded holes can be closed off with what is usually a 6mm bolt. Paint the exterior with Ford Silver Fox two-pack epoxy paint and the finish is beautiful and hard wearing.
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Offline boilermaker1
« Reply #9 on: February 22, 2016, 06:14:30 PM »
I painted my engine a few months ago,I did not strip the engine. I blocked all openings and had the engine bead blasted. Painted it Simonz engine enamel..This paint requires curing so  I had to make up a big plywood box and line it with tinfoil .
I purchased a cheap cooking thermometer on ebay, Used a heat gun to get it up to temp.
It took five hours to cure paint properly . very happy with end result.
I got the idea from sohc USA forum
« Reply #10 on: February 22, 2016, 07:18:15 PM »
I'm impressed with your diy oven idea.
Offline Chris400F
« Reply #11 on: February 22, 2016, 07:43:04 PM »
Me too. What sort of temperature do you need to cure the paint at?
Offline Rozabikes Tim
« Reply #12 on: February 22, 2016, 08:00:27 PM »
Just see it now. Have you been cooking the roast in my oven Dorris?
Excellent though in All seriousness.
« Reply #13 on: February 23, 2016, 08:50:46 AM »
Chips with that ? US Automotive VHT 200c for one hour.
« Last Edit: February 23, 2016, 08:56:12 AM by Spitfire »
Offline Valentinik
« Reply #14 on: February 23, 2016, 11:13:00 AM »
This was going to be my method but the wife was adamant that it wasn't as it would make the oven smell  >:(
Mike
