Author Topic: Air filter retaining Spring and cover  (Read 1025 times)
Offline paulbaker1954
« on: March 10, 2016, 02:11:39 PM »
1) My recently bought bike is missing the spring retaining the air filer and I cant source one from either DS or CMSNL. Is not having it important ie does it serve a technical function ie push the filter against the front seal maybe?
2) I am also a bit confused about covers as I bought the bike as a US import and not only no spring but no covers fitted either. Should there be a cover? I see a cover on the parts list (item8 on pic) but it doesnt look as if it covers the whole air filter like say on a car. So as with spring ? what's it's purpose, functional or cosmetic?
3) there is also a tool tray missing but I am eally not fussed about that I may pick one up on flea bay at some point.
Bottom line does any of these missing bits matter as it's all under the seat anyway
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Air filter retaining Spring and cover
« Reply #1 on: March 10, 2016, 03:14:34 PM »
  on my CB500 it has a spring,very much needed to push the element to the seal,Item 3,and a sealing top piece,item 8
http://www.cmsnl.com/honda-cb500-four-k1-england_model14660/partslist/F13.html#results
above these you also need tool tray item 8,and gauze cover,item 9
http://www.cmsnl.com/honda-cb500-four-k1-england_model14660/partslist/F36.html#results
 the spring is just a shaped flat steel item,but the other items are quite rare
 I would suggest ALL of the items are needed,unless you want to run with just the airbox and no filter
« Last Edit: March 10, 2016, 03:17:15 PM by Johnwebley »
« Reply #2 on: March 10, 2016, 03:31:37 PM »
A retaining spring you can easily make yourself. The socalled 'DUCT ASSY., AIR CLEANER' (17340-323-610) over the filtercase is on models with 649A carbs only.
Offline ST1100
« Reply #3 on: March 10, 2016, 06:14:14 PM »
PO of my '76 K2 simply stuffed a piece of worn timing chain tensioner into there...  ;)
STOC #637
