Author Topic: cb550 ignition timing  (Read 11185 times)
DougVinicombe
« on: January 04, 2005, 02:15:08 PM »
Can anyone help with setting the ignition timing on CB550. Using the manual and MC Mechnais guide I cannot get the timing marks anywhere near. Points & condenser have only done a few hundred miles. If I get1-4 near, 2-3 cannot be got anywhere near and I am using good quality strobe and dwel meter. Is there a special knack????.
fothers
RE:cb550 ignition timing
« Reply #1 on: May 08, 2005, 06:28:20 AM »
Quote
Hi Doug,
Are you using the Haynes manual? I changed the camshaft in my 77 550F2 and found that I had to turn the stator almost as far as the slots would allow in order to get the right gap on 1.4. Then I had to go to almost full adjustment on the 2.3 set.. Wierd, because I had marked the stator first and the marks (after setting the camshaft notch and getting compression/valve closing on the right cylinders etc) were nowhere near. I decided that I'd have a go anyway and the bike starts and runs better!
Maybe you just have to keep adjusting and don't be surprised if it looks miles out.
Cheers,
Pete.
slade
Re:cb550 ignition timing
« Reply #2 on: December 12, 2005, 10:24:26 AM »
The easyiest way to cure that problem is to buy a newtronics (used to be called pirhana) or boyer bransden electronic ignition, costs about
« Reply #3 on: December 12, 2005, 12:33:59 PM »
This is a common problem reported by many 350-750/4 owners.
The best response was posted by \"TwoTired\" on www.sohc4.net in the Ignition FAQ.  If I can get a direct link I'll post it.
Steve
2022 Tiger Sport 660
