Author Topic: Brake master cylinder. Rebuild oem or pattern?  (Read 1422 times)
Offline gtmdriver
« on: April 05, 2016, 11:20:04 AM »
My 1974 CB350F could do with some work on the front brakes.
Pacre Classic are selling pattern replacement master cylinders for £56 or so.
Does anyone have any experience with this component or the company in general?
Are these parts any good or should I rebuild my 42 year old component?
Offline Coppertop1234
Re: Brake master cylinder. Rebuild oem or pattern?
« Reply #1 on: April 05, 2016, 11:26:09 AM »
I would personally buy a seal kit for the existing master cylinder,they range from about £14 for pattern parts to about £20.00 for original.
Easy enough to replace with a bit of patience
cheers
Keith Snr
I Love Tinkering with Old Classics
Offline Chris400F
« Reply #2 on: April 05, 2016, 11:32:37 AM »
Personally I wouldn't replace unless it is actually broken.
No experience with Pacre but I did rebuild my 400/4 MC using an aftermarket kit from DS.
Their aftermarket kit is £23.00 + everything, a genuine kit from them is £29.95 plus everything.
Has Coppertop got a cheap source of supply?
DS also do a complete aftermarket MC for £29.00 + everything - work that one out!
Replacement is not difficult as long as you have a pair of long circlip pliers to remove the internal circlip.
I also noticed (after having bought the DS parts) that Cruzinimage do a rebuild kit at £16.40 inc delivery.
Their carb kits are OK, don't know if the brake kit would be any good. It is certainly a cheaper option.
« Last Edit: April 05, 2016, 11:39:08 AM by Chris400F »
« Reply #3 on: April 05, 2016, 12:43:41 PM »
  I bought a replica master cylinder from DS,
 had it about 3 yrs,looks good,works perfectly,
you choose if you want the work of swaping the internals
« Reply #4 on: April 05, 2016, 01:31:41 PM »
I would go with John W with this as it is the cheapest way and the OEM one may be past the point of no return once taken apart.
« Reply #5 on: April 05, 2016, 02:05:12 PM »
Spoken to Peter at Pacre a few times ...seems a decent guy.
Offline flatfour
« Reply #6 on: April 05, 2016, 02:46:02 PM »
My CB750 has the DS replica master cylinder fitted, my CB500 the original. Nothing to choose between them in terms of feel etc. in my opinion.
