Author Topic: Rounded head  (Read 2994 times)
Offline masonmart
Re: Rounded head
« Reply #15 on: April 06, 2016, 12:11:19 PM »
I had the same problem with every phillips head screw on the bike.
Therein lies the problem, they're not Phillips screws, they're JIS! Using a Phillips driver will cause it to 'cam out' and slip if any serious torque is applied.
This page explains, with a diagram.
http://www.vesseltools.com/hand-tools/screwdrivers/jis-japanese-industrial-standard/view-all-products.html
After taking all the allen screws out of my bike and going back to the OEM silver chocolate ones, buying JIS screwdrivers was essential, I found a reasonably priced pair on eBay.
Yes understood but I call them all Phillips screws. I had the right bits for the impact drivers and screw drivers so rounding wasn't a problem only getting enough torque on them to move them. My bike and engine were seriously corroded though.
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Re: Rounded head
« Reply #16 on: April 06, 2016, 03:53:40 PM »
If you grind a small amount from the tip on a PH2 it will fit a JIS without camming out.
Offline Carb17
Re: Rounded head
« Reply #17 on: April 06, 2016, 11:18:12 PM »
Thanks for everyone's help , I'm sure it will not be long until my next post !
