Author Topic: oil tank breather  (Read 1317 times)
Offline diabolics
oil tank breather
« on: April 07, 2016, 05:21:46 PM »
Hi, the oil tank on my K2 has a small breather pipe on the top under the seat. It looks that there should be a pipe attatched to it. The previous owner had blocked it off with a small piece of pipe and a bolt this I knew was wrong. There is no mention of it in the Haynes manual that I can find. Should the breather pipe from the top of the engine connect to it. Oil comes out of the tank breather under load. Any helo appreciated.  Thanks Adrian
Offline steff750
  • THE POWER OF DREAMS
Re: oil tank breather
« Reply #1 on: April 07, 2016, 06:56:26 PM »
Quote
no the top pipe should hang down just like the engine breather,and the lower smaller pipe goes to the back of the gearbox
Offline diabolics
« Reply #2 on: April 08, 2016, 08:39:59 AM »
Ok thanks. Will have s look later today if I can. Can't think why oil should come out of the oil tank breather has snyone any ideas ?.
Offline diabolics
« Reply #3 on: April 08, 2016, 09:35:55 AM »
Me again,could anyone send me a pic of where these breather pipes should go. Previous owner had a little play around I think and they don't exist in the Haynes manual. Thanks again Adrian
« Reply #4 on: April 08, 2016, 10:36:23 AM »
It looks like it was an issue for the previous owner too, if it was blocked off. Engines usually chuck oil out of breathers when there is pressure in the crankcase / rocker cover. That could be blowby from worn pistons or rings, or other causes, you may have to consider pulling the engine and have a look in there.
