Author Topic: Rear Light Bracket  (Read 2549 times)
Offline Chris400F
Rear Light Bracket
« on: April 08, 2016, 12:01:30 PM »
Probably an easy one for the experts out there.
Came across this in a box of bits.
Looks pretty much the same as others I have seen and mounting positions are the same but construction is different.
Outer part is made of two pieces rather than one (overlap can be seen near the top of the number plate mount).
There is also a ridge down the centre rather than it being smooth.
Is this just an earlier version of the part? Thanks.
Re: Rear Light Bracket
« Reply #1 on: April 08, 2016, 12:15:55 PM »
  that looks the same as my 500
« Reply #2 on: April 08, 2016, 04:23:27 PM »
Want to sell it Chris?
Offline Chris400F
« Reply #3 on: April 08, 2016, 08:22:34 PM »
Make me an offer ....
« Reply #4 on: April 08, 2016, 08:30:56 PM »
Name your price ..:-) !
« Reply #5 on: April 08, 2016, 08:38:50 PM »
I will start the bid at 99p ;)
Offline Chris400F
« Reply #6 on: April 08, 2016, 08:55:00 PM »
Sounds like the standard Trigger starting offer!
PM sent James.
« Reply #7 on: April 09, 2016, 09:01:53 PM »
Don't let the buggers con you!! that's a 500 one, slightly different from 750 in the details you mentioned
Offline Chris400F
« Reply #8 on: April 10, 2016, 10:07:26 AM »
Just for interest, to complete the story
Following John's initial response (thanks John) plus some rummaging in Parts Lists (thanks Ash) and a bit of Googling for good measure it seems that the bracket P/N is 84701-323-600B and it only fitted to 500/4 K0 and K1 UK models and 750/4 K2 UK models.
Now sold to James's mate for his 750 K2 rebuild.
