Author Topic: 4-1 to 4-2  (Read 4716 times)
Offline El__burro
4-1 to 4-2
« on: May 08, 2016, 12:17:14 AM »
Good morning,
a very simple question,
is it possible to adapt this 4-1 (photo below) into a 4-2.
I really like the look of the exhaust on both side but cannot effort a 4-2 or 4-4.
el__burro
Offline El__burro
Re: 4-1 to 4-2
« Reply #1 on: May 09, 2016, 10:22:40 PM »
any idea anyone?
Offline mick
Re: 4-1 to 4-2
« Reply #2 on: May 09, 2016, 10:30:27 PM »
Anything is possible with some patience and a welder  ;) cheers mick.
Re: 4-1 to 4-2
« Reply #3 on: May 09, 2016, 10:42:56 PM »
to get the best effect,and most efficient breathing,ideally link 2 and 3 ,and 1 and 4,
it might make the pipe work complicated,
Offline Honda Al
Re: 4-1 to 4-2
« Reply #4 on: May 10, 2016, 08:08:10 AM »
I know you mentioned cost, but have you seen the Marving 4-2 system? I bought one because the exhaust the bike came with was horrendous. It fitted well and looks quite smart with the pipes going each side of the bike.
Greebo
Re: 4-1 to 4-2
« Reply #5 on: May 10, 2016, 10:09:39 AM »
I bought mine from here ...Version#4 retro dunstall...they sound terrific
http://www.cyclexchange.net/Honda%20SOHC%20High%20Performance%20Exhaust%20Page.htm
they worked out with delivery at £485.00 ish....well worth it if you can get the cash together
Re: 4-1 to 4-2
« Reply #6 on: May 10, 2016, 08:12:52 PM »
Maybe worth contacting James H as he must have shed loads by now.
Offline El__burro
Re: 4-1 to 4-2
« Reply #7 on: May 10, 2016, 11:59:26 PM »
James H ?
Re: 4-1 to 4-2
« Reply #8 on: May 11, 2016, 08:08:14 AM »
James_Sussex
Offline El__burro
Re: 4-1 to 4-2
« Reply #9 on: May 11, 2016, 12:10:15 PM »
Thanks,
can 1976 exhaust fit 1972 bike?
El__burro
Offline El__burro
Re: 4-1 to 4-2
« Reply #10 on: May 12, 2016, 09:35:50 PM »
Anyone?
Re: 4-1 to 4-2
« Reply #11 on: May 12, 2016, 10:03:28 PM »
Mostly I think they'll all fit each other, some of the later (F2) use a different head fitting arrangement but can be swapped over just by using the correct parts.
So for example 1976 K6 will fit 1972 K2 if that's what you've got available.
Offline El__burro
Re: 4-1 to 4-2
« Reply #12 on: February 13, 2017, 01:47:38 PM »
catching up on this "project "
I have managed to make the 4-2 system using som cb parts and a Y piece from another vehicle.
the result is not bad.
to improve it I need to relocate the side stand SPRING.
I've tried a few options but unsuccessfully.
can anyone help me with this?
the spring touches on the y piece and i guess it will damage on the long term.
el__burro
Offline Mag1
Re: 4-1 to 4-2
« Reply #13 on: February 13, 2017, 08:14:38 PM »
Does it just touch it and no more or does it interfer with the actual branch of the exhaust. The most important thing is does the stand move completely out of the way while on the move in its full tucked away position?.
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Offline El__burro
Re: 4-1 to 4-2
« Reply #14 on: February 15, 2017, 02:32:42 PM »
the spring was touching the collector pipe, i am sure within a year of using the side stand it would have damaged it.
i fixed it by welding a support on the back of the existing one and another one on the back of the stand itself.
i'll upload pics soon.
In the meantime i am sharing the final result.
What do you think?
El__burro
