Project Board
CR750 replica build
4
5
6
7
18
Topic: CR750 replica build (Read 237009 times)
Johnwebley
Re: CR750 replica build
Reply #60 on:
February 07, 2017, 06:24:29 PM »
Bloody hell,that is some machining !!
keep up the good work
captaink
Old racers never die. ' they just go faster '
SOHC Expert
Reply #61 on:
February 27, 2017, 05:02:46 PM »
Hi CR21,
Nice work so far,
I'm building my CR replica here in the UK.
Had a bit of a break but I'm back on it now.
I have the Asa Moyce tanks as well, they are nice bits of work...worth the wait.
Do you know what type of fuel tap works with that tank, I have been told its from a Honda motorcross but cant seem to track one down.
Also what are you thinking of doing for a front mudguard / fender.
Regards Keith
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International 1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
haynes66
Reply #62 on:
February 27, 2017, 05:06:26 PM »
welcome back, captaink! i was wondering how the rickman was coming along.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
philward
Reply #63 on:
February 27, 2017, 05:17:48 PM »
The fuel tap that Meadspead advised me was from a CR250 motocrosser - I got one from an Australian seller (
http://www.ebay.co.uk/itm/HONDA-CR250-80-07-GXMOTOR-FUEL-TAP-PETROL-TANK-PETCOCK-/141756762924?hash=item21015c8b2c:g:Yj0AAOSwTapV3XhE
). The original is a twin exit tap but you will have to search the .net site for that - don't know if they are available (H2eric on the ,net site got hold of one I seem to remember when reading a thread) - depends how for you want to go.
Its not a priority at the moment for me but the Bartel (Asa Moyce) tanks tap flange bolt holes are not 'blind' and so will need some effective thread sealing to prevent leakage via the thread on the bolts
captaink
SOHC Expert
Reply #64 on:
March 01, 2017, 03:57:45 PM »
The Rickman engine is complete and I plan to put it in the frame in a week or so.
I've done a bit on the CR in the last few weeks
I purchased another 1977 engine and stripped it to the bones, this has now been aqua cleaned and after accessing the work required I'll be sending it up to the engine man for machining.
The present thought is inspect crankshaft and either polish journals or regrind, new shells for the crank and rods.
As before I have got a big bore kit 836cc and it will be rebored to suit.
Head will have new APE valve guides, valves and springs.
APE casing and cylinder studs.
I also purchased another set of casings, cylinder, head and rocker cover to use as a dummy which will allow me to carry on with the project whilst the engine man Dave from D & M Engineering is doing the machine work.
Pictures show the clean but dummy engine.
Last Edit: March 01, 2017, 04:02:02 PM by captaink
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Reply #65 on:
March 01, 2017, 05:05:57 PM »
Nobody makes undersize shells so regrind don't work
Tomb
Reply #66 on:
March 02, 2017, 07:34:45 AM »
Bryan have you Capt'Ks list of bikes? must half a million quid there alone, if you have the money you can get anything done.
I once bored out a Royal Enfield conrod to take different shells, they came from an Austin Allegro that were 10 thou smaller ID to fit an undersize reground crank. It ran for years like that. As you can tell by the Allegro parts it was a looooong time ago.
Nice work Capt'K, no disrespect intended.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Reply #67 on:
March 02, 2017, 02:16:34 PM »
If you have the time and cash anything is possible but for us mortals it just ain't so, I did convert a pair of triumph white metalled rods from a 500 to shells but the customer didn't like the cost, from memory £25 in the late 70's
hairygit
Reply #68 on:
March 02, 2017, 04:02:25 PM »
Send it to S.E.P. in Kegworth, they build the crank up with submerged argon arc welding then regrind back to original spec. Can vouch for their quality of work.
MarkCR750
Professional half wit and member
Reply #69 on:
March 02, 2017, 08:27:11 PM »
Quote
"Bryan have you Capt'Ks list of bikes? must half a million quid there alone"
I don't think the value is anywhere near half a million, I've totted the bikes up and struggled to reach 464,000 😄, on a serious note though I too can vouch for SEP, you don't have to be in a hurry though because they are very very busy!.
(PS capt'K please will you be my friend?).
Last Edit: March 02, 2017, 08:45:07 PM by MarkCR750
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
captaink
SOHC Expert
Reply #70 on:
March 05, 2017, 05:58:54 AM »
Hi Mark,
I would be your friend but someone as mad as to "Almost " mask up his kitchen to paint his bike bits is some kind of nutter
I must admit though I did used to put the high temp painted cylinders for the older bikes in the oven to bake them, it makes the oven smell but does the job. And yes she had gone out shopping.
When I was much younger ( late 1970's ) I spray painted my car in the street, tried not to get overspray on the neighbours cars ! " those were the days "
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
MarkCR750
Reply #71 on:
March 05, 2017, 08:25:35 AM »
Fair enough capn'K I can understand that behaviour being off putting, although in some quarters it has almost given me hero status
PS I'm guessing that a side benefit of spray painting your car in the street was that it simultaneously marked out your parking bay?.
Last Edit: March 05, 2017, 08:29:19 AM by MarkCR750
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
CR21
SOHC Member
Reply #72 on:
March 16, 2017, 08:57:11 AM »
Hello all!
I have been off the forum for a while, but progress is happening on the build. Clip on bosses are completely machined now as are the rear set pinch bolts and front wheel speedo drive plates.
Captaink - your build looks great please keep updating your thread
With regards to fueltaps - the CR250 taps that fit the bartel tanks are still available from Honda. I am considering machining my own tap, but at the moment I have bigger things to progress on with the frame!
Update to come soon on the clip on bars/front end. Need to start thinking about designing and machining a splitter for the front brakes lines as well.
Cheers!
CR21
CR21
SOHC Member
Reply #73 on:
March 21, 2017, 11:26:28 AM »
Just a quick update:
Speedo drive adapter plate machined:
And the filler cap bezel to accept the 'correct' fuelcap:
More to come at the weekend, hopefully front wheel assembly and some movement on the clip-ons!
Cheers,
CR21
Last Edit: September 13, 2017, 12:21:20 PM by CR21
paul G
Reply #74 on:
March 21, 2017, 12:28:42 PM »
Everything about this build is impressive
P.S. Can you do me some rear sets for a Z650
4
5
6
7
18
Project Board
CR750 replica build
