Author Topic: CR750 replica build  (Read 197532 times)
Offline CR21
Re: CR750 replica build
« Reply #255 on: May 20, 2026, 08:09:26 AM »
The chinpad mould is complete, first out of the tool looks good  ;D
Disk spacer and rear shock mounts complete as well:
Cheers,
CR21
Offline CR21
« Reply #256 on: June 04, 2026, 08:56:40 AM »
Quick update - another mini project within this project!
I was originally planning on using a good quality GL1000 master cylinder for my project, however...
The original CR750 master cylinder was a different part than any street models, it had an angled reservoir and a bigger bore/output to handle the twin disk set-up.
It is hard to see in the ACU homologation files, and from this image of the late Tommy Robb:
I managed to borrow a genuine CR750 master cylinder for a few days (magnesium), 3D scanned this and have started the process of reverse engineering it. The cap is slightly different as well! I will likely use genuine GL1000 valving within the custom body, so that it can be rebuilt if needed in the future.
3D Scan results:
The CAD progress so far:
Cheers,
CR21
« Reply #257 on: Today at 10:34:17 AM »
Erm.....mind boggling to say the least! Your attention to detail is amazing.
So the big question is....how are you going to make it, from solid, 3D printing, casting?
Please keep a photographic record as this will be interesting to see👍
« Reply #258 on: Today at 03:32:32 PM »
I'm beginning to wonder if this whole build is an AI generated entity,  it's so detailed & perfect.😃
