Author Topic: PD carb query  (Read 5732 times)
Offline MarkCR750
PD carb query
« on: May 28, 2016, 02:50:36 PM »
Please could someone with PD carbs have a look at their No1 carb and tell me if there should be a small brass blanking plug or similar in the small hole in the side of my carb, it's in the centre of the photo below and you can see a light coloured vapour mark on the carb body just below it, my tickover dropped earlier today, I just squirted carb cleaner in the small balance pipes in the back of the carb and it came out of that hole, it's never done that before! 😀.
PS I can see the same feature on the No2 carb, squirting carb cleaner in No2 does not result in it coming out of the side, so the question now is should it?, are these holes vents to atmosphere to achieve a balance between the intake and atmosphere?, maybe?, confused at present.
« Last Edit: May 28, 2016, 03:24:32 PM by MarkCR750 »
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Re: PD carb query
« Reply #1 on: May 28, 2016, 03:30:57 PM »
Just had a look at some on F2 750 and they are different in that the part you are looking at has a much longer nose sticking out on the example here to about 10\15mm further than yours.
I can't quite see inside the casting to give an accurate idea of what's in there and the photo I've taken is in shadow down inside there, will try to investigate further.
Re: PD carb query
« Reply #2 on: May 28, 2016, 04:13:18 PM »
Still can't get camera flash and lens to point down the casting hole to get you a picture,  but if I put a tube onto that hole you can pull a vacuum on it and it flows no air so on that basis it should be sealed as far as I can see.
Hope that helps.
Nigel.
Offline MarkCR750
Re: PD carb query
« Reply #3 on: May 28, 2016, 06:00:40 PM »
Thanks Nigel, it's odd the way that the casting slightly "hoods" the hole, like it's supposed to be open, I'll see if I can find a diagram that shows it.
PS I don't think the answer to my question is in the link below but it is a brilliant how to on PD carbs.
http://www.motopsyco.com/2013/08/09/vintage-piston-valve-keihin-carburetor-overhaul/
« Last Edit: May 28, 2016, 06:30:49 PM by MarkCR750 »
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Re: PD carb query
« Reply #4 on: May 28, 2016, 08:30:25 PM »
It's good when people go to that effort to show others through something.
I know there's not alot of people like the PD carbs as they are fiddly to work with but they did work well originally in my experience, I also think they are definitely the right philosophy in that they run under constant load with a leaner mix and just richen for the acceleration demand. Means you get less fuel unburnt to contaminate the oil along with probably less bore wear.
This is after all what weber twin chokes on cars do and the American pumper carbs on older V8s which nobody complains about.
Re: PD carb query
« Reply #5 on: May 28, 2016, 08:38:45 PM »
Compared to PD carbs, the old Holley's on my mustang many years ago were great, you could probably use a broom handle to clean jets, and the accelerator pump could probably pump the titanic out to refloat it in about 10 pumps!
Re: PD carb query
« Reply #6 on: May 28, 2016, 09:09:02 PM »
One of life's great pleasures, sitting behind a nice V8 with the throttle wide open.
I've never owned a big yank V8 but spent alot of time with rovers and currently have a 3.9 on injection in a old Range Rover.
Offline onethumb
Re: PD carb query
« Reply #7 on: June 24, 2016, 02:02:01 PM »
Dude they some of the cleanest pd carbs I've seen. Mine are in a box and don't look that clean!
Offline MarkCR750
Re: PD carb query
« Reply #8 on: June 24, 2016, 02:27:54 PM »
That's cos yours aren't painted 😄
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Greebo
Re: PD carb query
« Reply #9 on: June 24, 2016, 04:09:43 PM »
Hi Mark
I have been fiddling with my carbs for while & used plenty of carb cleaner as you , but I have not had any leakage of any kind from the very small hole that you are asking about. on my carbs that small hole looks like its sealed.
Offline MarkCR750
Re: PD carb query
« Reply #10 on: June 24, 2016, 04:32:51 PM »
I've googled it a fair bit but can't find anything , I actually think they should be open to atmosphere, that's because of the way the alloy is moulded above the hole,  like a hood, really not sure though , I'll do some more googling.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Re: PD carb query
« Reply #11 on: June 24, 2016, 06:29:29 PM »
There is a piece of alloy that looks like a tube connector missing off yours. The butcher has been at work there. I will try and get a usable photo of mine if I can. It should defo be blanked and not leaking.
Re: PD carb query
« Reply #12 on: June 24, 2016, 06:32:35 PM »
Managed to find a picture of mine, you can just see the tube type alloy piece here. All 4 carbs have a similar thing between 1&2 and 3&4 that face each other and look like they were at one time connected with a pipe, these have a brass insert to blank them. Only carb 1 has this extra hose fitting on the outside. It is completely sealed and the casting has never been drilled. Hope that helps.
« Last Edit: June 24, 2016, 06:41:59 PM by royhall »
Offline MarkCR750
Re: PD carb query
« Reply #13 on: June 24, 2016, 06:43:46 PM »
Harrisluv from the US site has spoken, looks like its specific to the 77 model, thanks for your replies all
HARRISLUV
On the 77 PD carbs, there is no vent tubing between the carbs.  Instead, each carb has its own individual vent hole.  It's really tiny.  It should be clear and open.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Re: PD carb query
« Reply #14 on: June 24, 2016, 07:37:25 PM »
I don't agree with that. My carbs in that picture are PD41B circa 1977 F2. The later carbs are PD42B circa 1978 onwards (possibly K7 1977). The bodies on both the F2 & K7 are the same just the jetting is different. That nozzle casting on mine has never been drilled and is airtight. Defo not a vent of any kind, the vents I believe are the 4 inner tubes facing each other.
« Last Edit: June 24, 2016, 07:52:12 PM by royhall »
