Author Topic: Bike won't start - help!  (Read 47919 times)
Offline JustcallmeMrT
« on: May 29, 2016, 05:36:30 PM »
Well gents, after a blissful week of riding, my bike no longer starts, and I can't figure out why for the life of me.
It became harder to start over the course of a few days, but now refuses to catch at all.
I have done the following:
-checked valve clearances
-checked static timing
-cleaned and gapped the points
-replaced condensers and spark plugs - spark seems ok
-checked function of coils - all values fall within normal ranges
-replaced battery
-checked frame grounding points for corrosion, found none.
-sprayed easy start directly into the intakes, no go.
What could it be?  I'm all out of ideas.
Sent from my SM-N9005 using Tapatalk
Re: Bike won't start - help!
« Reply #1 on: May 29, 2016, 06:08:58 PM »
if you have sparks,and compression,
 make sure you have plenty of fresh petrol,
« Reply #2 on: May 29, 2016, 06:10:11 PM »
Not sure on the compression, trying to borrow a gauge to test.  Fuel is fresh.
« Reply #3 on: May 29, 2016, 07:12:55 PM »
 put the petrol tap on reserve,remove a carb bowl drain screw.make sure you have a flow
« Reply #4 on: May 29, 2016, 08:06:48 PM »
Yep, definitely flowing.
Offline petermigreen
« Reply #5 on: May 29, 2016, 08:23:35 PM »
Blocked air flow/filter?
« Reply #6 on: May 29, 2016, 10:33:06 PM »
New K&N filters, only 200 miles on the bike since it was dyno tuned to suit them and the new exhaust.
« Reply #7 on: May 30, 2016, 08:26:32 AM »
If it will not fire on easy start, I would assume (without seeing the bike) that it must be a firing problem. When I come across this in the workshop, I would try to bump start the bike and if it would not fire on easy start with a bump I would always be back to the drawing board while a lot of head scratching went on.
« Reply #8 on: May 30, 2016, 08:28:14 AM »
Will try a bump start then!
« Reply #9 on: May 30, 2016, 08:33:28 AM »
It is very hard to comment when a bike is not in front of you.
« Reply #10 on: May 30, 2016, 08:36:38 AM »
I know.  If I had a van I'd bring it by.
« Reply #11 on: May 30, 2016, 09:24:05 AM »
Try turning it over with choke fully on first then remove choke and hold throttle wide open to see if you get any response at all, if it doesn't fire it should probably at least give you a cough or maybe a backfire. You can do this either on the starter or by bumping it.
Offline Seabeowner
« Reply #12 on: May 30, 2016, 12:34:02 PM »
Mr T. Not a lot of help today, as going away. But am only just down the road in Maidenhead. PM me if you like and we can compare notes etc. Back 9th.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Chris400F
« Reply #13 on: May 30, 2016, 01:06:22 PM »
After you've tried starting it are the plugs wet (possibly implying unburnt fuel, no spark) or dry (possibly implying no fuel)?
« Reply #14 on: May 30, 2016, 01:07:30 PM »
The plugs are wet after starting, but seem to have spark?
